Question about Miele Dishwashers
Miele dishwasher G7860 - problem: F11 fault - Miele Dishwashers
Krazytech
  • 725 Answers
SOURCE: Got a Miele G2220sci dishwasher
F19 is water in the cabinet takes too long to heat up. you can reset the heater limiter..
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. If the fault message reappears
take off service panel press button on the heater limiter red-brown located on the left side of the plinth...
hope it helps
Posted on Sep 07, 2008
  • 30 Answers
SOURCE: Miele Optima dishwasher. Doesn't drain,
check the drain solenoid valve if working properly or check if voltage is present if you press the drain switch.
Posted on Aug 12, 2010
ginko
  • 19396 Answers
SOURCE: on my miele dishwasher G1220
Hi.
The slide shutter is part of the circulation pump assembly. Disconnect pump and check for blockage at pump hose. If that does not help replace the circulation pump.
Regards.
Ginko.
Posted on Feb 19, 2011
ZJLimited
  • 17970 Answers
SOURCE: Have just bought a secondhand
F11 - Drainage fault
This code means that water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Background information:
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause:
Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause:
Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause:
Foreign objects in heater pressure switch.
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause:
Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
Replace the heater relay.
In other cases, owners found a piece of wood inside the door latch mechanism and removed it. The F11 error has not appeared since.
Hope ths helps.
Posted on May 20, 2011
  • 251 Answers
SOURCE: Miele LaPerla Dishwasher showed fault
Hi - I have not come across a fault code F147 on a miele dishwasher, the highest being F112, are you sure its not F47 instead, this relates to a faulty electronic controller unit.
From what I know of LaPerla the model G2830 series and even the faults does not have a F147 amongst the chart.
Posted on Jun 15, 2011
Water remains in machine. Machine stops after a minute or so and diplays F11.
F11 means Drainage fault.
Water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Remedy:
Cause: Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Remedy:
Cause: Drain pump defective.
Remedy:
Cause: Foreign objects in heater pressure switch.
Remedy:
Cause: Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
Hope this helps to solve it.
Jul 05, 2011 | Miele G2432SCISS Builtin Dishwasher
Miele LaPerla Dishwasher showed fault code F174 at 27 hours operation. How can I get a copy of the Miele fault codes? I pay for Remote Monitor and did not receive an alert. What is fault code F174?
Jun 08, 2011 | Miele Premier-Plus Built-in Dishwasher
Have just bought a secondhand Miele G7859 dishwasher. When turning on to any programme, it shows F11 fault code and beeps. I'll happily work through any suggestions! Thanks in advance Andy
Remedy:
Cause:
Remedy:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Hope ths helps.
May 20, 2011 | Dishwashers
Miele Optima dishwasher. Doesn't drain, and display says "F11"
Aug 12, 2010 | Miele Dishwashers
Dishwasher not draining
you need to remove the drain pump motor and see what is obstructing the impellar.(small shreds of glass:small popcorn pieces etc. Doesnt take much to stop the drain pump.Try and get to drain pump from the front. Miele very compact.
May 28, 2010 | Miele Incognito G818SCVi Built-in...
WHAT IS F11 ERROR MIELE DISHASHER G 1232 SC
hi
this is a drain fault. you will probably find the drain spigot under the sink is blocked where the drain hose connects.
Dec 13, 2009 | Miele G892SC SS Dishwasher
Fault 11 - inlet or outlet blockage
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Jun 14, 2009 | Miele Incognito G658 SCVi Built-in...
Got a Miele G2220sci dishwasher unit, getting an undocumented error code of F19 with flashing lights, help! what does F19 mean? WONT DRAIN. PROGRAM FINISHES WITH F11
Hi again,
At your convenience would appreciate how the Miele dishwasher is now?
Hope this be of more help/idea in the future. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 07, 2008 | Dishwashers
CODE F11 ON MIELE 1220 SCH
I disconnected the drain where it enters the S bend from the sink. I found the nozzle into the S bend was blocked. I probed this with a screwdriver and cleared the blockage then I reconnected the drain. I turned on the dishwasher again and the F11 code was cleared. The dishwasher operated ok again.
May 14, 2008 | Dishwashers
Dishwashers Logo
214 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
