Question about Garden
I removed a bedroom door and when I put it back the door won't close
  • 56 Answers
When you put the door back on was the door closed? If not that is what you need to do to put it back in line.
Posted on Sep 15, 2011
Door won t close properly
Using a long screwdriver to change to position manually is the obvious solution. This tech assumes you've tried and failed.with electromagnetics involved you would need to get back in control of the moving devices. First remove the fuse that controls the door locks now try screwdriver. N/G try removing the pos+ batt lead now try manual manipulation. all else fail door panel off / eyeball what's binding up / component replacement. Hope it helps
Jun 17, 2014 | 1999 Chevrolet Cavalier
The lock got flipped on the bedroom door. I am now locked out. The door knob has been removed but I cannot get the mechanism inside the door unlocked. How can I do this?
You are almost there. Take the knob containing the spindle and insert into the latch mechanism. Twist it and the lock button will pop out. Open the door. Put everything back together. NOTE: I just confirmed this using a lock mechanism in front of me as I answered this.
Nov 09, 2013 | Hardware & Accessories
Door ajar light stays on door won't close all the way
-Just disconnect the wire that hook up to the switch.
(Only on the effect door)
-Or remove the switch and if you can put a spacer to bring the swtich
to the outside little more. That will solve the problem.
mai
Mar 21, 2013 | Dodge Caravan Cars & Trucks
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
The Driver's side door of our 1996 Saturn Stationwagon won't catch when you close the door. In otherwords, if I drove the car, I can close the door but it doesn't catch and therefore the door...
first make sure the bolts which hold the latch mechanism to the door are firmly screwed in. if that ain't it, remove the post which it clamps onto from the door jamb and switch it with one from a back door. close the back door firmly, lock it and never use it again. if that ain't it go to www.getsaturnparts.com and buy yourself a new door latch mechanism and pay an auto glass shop to put it in for you.
Sep 07, 2011 | Saturn SW2 Cars & Trucks
I have a whirlpool electric range model no. RF378LXKQ0. I removed the door and now I can't get it back on. I didn't relalize I was to put the pins in and I don't even see where they go.
**** the hinge to the broil position. Put a nail or something so the hinge won't pop back in the door when you go to put it back. Once ya have it back in the stove, remove the nail and close the door.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 07, 2011 | Whirlpool RF378 Electric Kitchen Range
Oven door has dropped & won't close properly
You may need new hinges or the door is possibly out of the hinge socket. Try removing door and putting it back in place. These instructions should be in your users manual.
Jun 17, 2011 | Ovens
I locked my bedroom door with my keys in the room
Look closely at the door knob and you will see a very small hole in the middle of the door knob. Use a piece of stiff metal such as a heavy paper clip straightened out and push it into that hole. that will unlock the door to your bedroom if you have a normal bedroom door lock.
Mar 25, 2011 | Garden
Tran A/c installed last summer
It's the ducting that causes the problem. But if the old unit wasn't as bad, did they install a smaller unit to save on money? It is possible, some companies do this to make more money. Sad but it is true. A return added to the room would help but if they can run a return, then they can add another duct or reduct the room as well. Sounds like someone is trying to sell you a story without fixing the issue. Tell them that they don't need to add an extra run, tell them to change the size! Also, make sure that if the run is longer than 25 feet, the ducting has to be stepped down in size to increase valocity to the vent. For example, you have a 10" duct running for 25' and then you step down to 8" the rest of the way unless that run is more than 25'. Hope this info helps!
Apr 02, 2009 | Heating & Cooling
Can't open bedroom door
Check to see if the wood or the lock is binding. Try this:
Leave door open and turn on heat. After a few hours, try to close door and see if it's catching on the frame. If it is, plane the door where it is binding. You can check for binding by using chalk on the door and after closing it, see where the scrub marks are.
If it's the lock, take out the striker plate and using a chisel, make the cut out deeper. Install the striker plate and test it again.
Oct 22, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
