Question about La Pavoni Europiccola EPBB-8 Espresso Machine
I'm having a small leak from the bottom of the sight glass. How do I go about disassembling the sight glass to repair it?
  • 3 more comments
  • b_greenbank Apr 11, 2011
    Many thanks for your response. However, I believe the small leak is through the lower of the two bolts which hold the sight glass to the body and I would still like to be able to disassemble and replace some of the sight glass components but how to do so is my problem.
    Bud
  • b_greenbank Apr 13, 2011
    Many thanks - I rather feared this would be the case. I regularly service my machine and am comfortable with disassembling the group but I wouldn't know where to start on the boiler. Oh dear :(
    Bud
    Thanks very much. I rather feared this would be the case. I regularly service the machine myself and am comfortable disassembling the group but I wouldn't know where to start on the boiler - oh dear :(
    Bud
    That's absolutely brilliant - many thanks. I'll give it a go - once I've plucked up the nerve !!!
    Bud
  • b_greenbank May 06, 2011
    Finally managed it. Just wanted to say how grateful I am for the expert advice you gave me. Many thanks
    Bud
  • 794 Answers
Hi b_greenbank,
Do you have further inquiry about the machine? Just let us know so we can assist you.
Thank you for using FixYa.
Posted on May 07, 2011
    Guru:
  • 1,833 Answers
First Make sure top cap of aerator is seated properly and the pin is in the down position. Because, for this position it may occur. If you have to disassemble the sight glass then turn the machine off and unplug it. Release the existing steam in the boiler. Remove the boiler cap by turning it anticlockwise and discharge the water totally. The steam knob also must be closed. Open the glass holder and disassemble the glass.
Posted on May 06, 2011
  • 5,370 Answers
Try and unscrew the nut on top of the sightglass. You'll see that it's about 1/8'' and fairly short. It sits against a white seal that holds the upper part of the sight-glass.First of all, it would require a full disassemble of the boiler, as the upper sight glass mounting is only detachable with acces from inside the boiler. ---------- Check out.Keep updated.Thanks.Helpmech.
Posted on Apr 11, 2011
    Genius:
  • 1,157 Answers
Hi b_greenbank,
If you're experiencing water leaks from the machine, it might caused by broken or detached drain tube. There are some ways on how to resolve the problem, either you check the sewer drain or restore the connection of the drain tube to the tub. For additional information about your machine, please visit the links below.
Instruction for use model Europiccola EPBB-8
Instruction Manual
Hope it helps.
How do i know if i put too much oil in my bike
Look @ your sight glass. Left of engine lower bottom of casing. If too much oil is used a small amount of smoke may appear. LOL
Mar 07, 2014 | 2001 Yamaha V Star 1100 Classic
Campbell hausfeld 60 gallon sight glass oil leak
Try here http://www.about-air-compressors.com/campbell-hausfeld-air-compressors.html
Jul 30, 2012 | Campbell Hausfeld Air Tools & Compressors
Head pressure too low
Charge until the sight glass is full. I suspect your pressures will be be better. 12 psig is low even if the case is down to temp. I suspect once the sight glass is full you'l be runniing in the upper 20's.
Apr 02, 2012 | Freezers
Hi, My Kenners air conditioner seems to work for the 1st 10-15 or so, then it just seems like its blowing out air like a fan. There is no water that leaks from the bottom, what can be the...
System Inspection
Although the A/C system should not be serviced by the do-it-yourselfer, preventive maintenance can be practiced and A/C system inspections can be performed to help maintain the efficiency of the vehicle's A/C system. For A/C system inspection, perform the following: The easiest and often most important check for the air conditioning system consists of a visual inspection of the system components. Visually inspect the air conditioning system for refrigerant leaks, damaged compressor clutch, abnormal compressor drive belt tension and/or condition, plugged evaporator drain tube, blocked condenser fins, disconnected or broken wires, blown fuses, corroded connections and poor insulation.
CHECKING FOR OIL LEAKS Refrigerant leaks show up as oily areas on the various components because the compressor oil is transported around the entire system along with the refrigerant. Look for oily spots on all the hoses and lines, and especially on the hose and tubing connections. If there are oily deposits, the system may have a leak, and you should have it checked by a certified air conditioning specialist.
Fig. 1: Run your hand along the underside of all hose connections and check for leaks. If you find a leak, have it fixed by a certified air conditioning specialist.
check%20ac%20leak.jpg KEEPING THE CONDENSER CLEAR Periodically inspect the front of the condenser for bent fins or foreign material (dirt, bugs, leaves, etc.). If any cooling fins are bent, straighten them carefully. You can remove any debris with a stiff bristle brush.
Fig. 1: The position of the condenser in front of the radiator makes it particularly susceptible to collecting debris. Periodically, remove the accumulated bugs, leaves and other trash from the condenser. ac%202.gif
CHECKING THE REFRIGERANT LEVEL There are two ways to check refrigerant level. On vehicles equipped with sight glasses, checking the refrigerant level is a simple matter. Many late model vehicles, however, do not have a sight glass, and you have to check the temperature of the lines to determine the refrigerant level.
With Sight Glass The sight glass is normally located in the head of the receiver/drier. The receiver/drier is not hard to locate. It's a large metal cylinder that looks something like a fire extinguisher. Sometimes the sight glass is located in one of the metal lines leading from the top of the receiver/drier. Once you've found it, wipe it clean and proceed as follows:
  1. With the engine and the air conditioning system running, look for the flow of refrigerant through the sight glass. If the air conditioner is working properly, you'll be able to see a continuous flow of clear refrigerant through the sight glass, with perhaps an occasional bubble at very high temperatures.
  2. Cycle the air conditioner on and off to make sure what you are seeing is clear refrigerant. Since the refrigerant is clear, it is possible to mistake a completely discharged system for one that is fully charged. Turn the system off and watch the sight glass. If there is refrigerant in the system, you'll see bubbles during the off cycle. If you observe no bubbles when the system is running, and the airflow from the unit in the vehicle is delivering cold air, everything is OK.
  3. If you observe bubbles in the sight glass while the system is operating, the system is low on refrigerant. Have it checked by a professional.
  4. Oil streaks in the sight glass are an indication of trouble. Most of the time, if you see oil in the sight glass, it will appear as a series of streaks, although occasionally it may be a solid stream of oil. In either case, it means that part of the charge has been lost.
  1. Fig. 1: Oils streaks (A), constant bubbles (B) or foam (C) indicate there is not enough refrigerant in the system. Occasional bubbles during the initial operation are normal. A clear sight glass indicates a proper charge of refrigerant or no refrigerant at all, which can be determined by the presence of cold air at the outlets in the vehicle. If the glass is clouded with a milky white substance, have the receiver/dryer checked by a certified air conditioning specialist. ac%203.jpg
Without Sight Glass On vehicles that are not equipped with sight glasses, it is necessary to feel the temperature difference in the inlet and outlet lines at the receiver/drier to gauge the refrigerant level. Use the following procedure:
  1. Locate the receiver/drier. It will generally be up front near the condenser. It is shaped like a small fire extinguisher and will always have two lines connected to it. One line goes to the expansion valve and the other goes to the condenser.
  2. With the engine and the air conditioner running, hold a line in each hand and gauge their relative temperatures. If they are the same approximate temperatures, the system is correctly charged.
  3. If the line from the expansion valve to the receiver/drier is a lot colder than the line from the receiver/drier to the condenser, then the system is overcharged. It should be noted that this is an extremely rare condition.
  4. If the line that leads from the receiver/drier to the condenser is a lot colder than the other line, the system is undercharged.
  5. If the system is undercharged or overcharged, have it checked by a professional air conditioning mechanic.
Fig. 3: Checking the refrigerant charge if the system has no sight glass. ac%204.jpg
May 31, 2011 | Fedders A6P09S2A Air Conditioner
Leaking air conditioner, possible crack in drainage hole??
System Inspection
May 24, 2011 | Sharp CV10NH Air Conditioner
My "Alpine" air conditioner is
System Inspection
Feb 28, 2011 | AdobeAir Alpine® RW4500 Thru-Wall/Window...
Air conditioner cools good but does not take humidity out of room room gets very humid also can run small 5000 air unit and takes out a lot of humidity largre unit is 25000 btu for 900sq ft is it too big...
System Inspection
Feb 19, 2011 | Kenmore 73259 Air Conditioner
Air conditioner leaking water from the unit inside
System Inspection
Nov 14, 2010 | Whirlwind FH-778 Air Conditioner
How to set the floats on 1980 honda fcivic
YOU CHECK FLOAT LEVEL LOOKING AT THE SIGHT GLASS ON THE RIGHT OF THE CARBURETOR.FUEL LEVEL SHOULD ALIGN WITH THE DOT ON THE SIGHT GLASS.IF THE LEVEL IS ABOVE OR UNDER THE DOT THE CARBURETOR HAS TO BE DISASSEMBLED.TO SET FLOATS REMOVE AND INVERT THE AIR HORN UNTIL THE FLOAT ARM JUST TOUCHES THE NEEDLEVALVE OR THERE IS ABOUT 0.1 mm OR 0.004 INCH CLEARANCE BETWEEN THEM.MEASURE THE DISTANCE BETWEEN THE BOTTOM OF THE AIR HORN GASKET INSTALLED.AND THE CENTER OF THE BOTTOM OF THE FLOAT.THE DISTANCE SHOULD MEASURE 36.4 mm 1.39 - 1.47 INCH. ADJUST BY TURNING THE NEEDLE VALVE SEAT.BE CAREFUL NOT TO ALLOW THE VALVE SEAT TO PROTRUDE FROM THE SEAT ATTACHING BOSS.WHICH WOULD ALLOW THE VALVE TO FALL.IF THIS IS THE CASE BEND THE FLOAT ARM SLIGHTLY UNTIL PROPER CLEARANCE CAN BE OBTAINED.WHEN CARBURETOR IS INSTALLED CHECK FLOAT LEVEL BY LOOKING INTO THE CARBURETOR FLOAT SIGHT GLASS I MENTION IN INFORMATION ABOVE.IF YOU HAVE A 1487cc AND 1600cc CVCC MODELS WITH THE KEIHIN 3 BARREL CARBURETOR.THIS WOULD DEALERSHIP JOB.THIS TYPE IS HARD TO ADJUST.
Jan 30, 2010 | 1983 Honda Civic
La Pavoni Europiccola EPBB-8 Espresso Machine Logo
201 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
