Been on charge for 24 hours red light on but still not flashing to say fully charged
  • 6,771 Answers
The rechargeable battery in your MP3 player needs to be replaced, generally speaking the average life span for a battery is 1 to 3 years.
Posted on Mar 19, 2011
New gmr 3055-2ck work fine just charming indictater on charge won't stop have charged twenty-four hours lights still flash
Make certain you are charging with the radio OFF. If on, the radio will use a small amount of energy and the charger will not know the battery is fully charged. If you intend to leave it on the charger, ON as in standby, then the lights will always flash. I would put a timer on the wall adapter so the battery is not always being charged. A battery always being charged will not last long, likely get hot and may cause problems. These are light duty radios, not designed for 24 hour if even daily use.
Jul 12, 2016 | Uniden Radio Communications
Battery red light staying on after 24 hours charge Manual states red light should go off when fully charged
Either the charger is not working, the battery will no longer take a full charge, or the detection of a full charge is not working. If the trimmer works as long as it used to after charging 24 hours I would not worry about it. If not, then try to find another charger that has the same volt AND amperage rating and the same end (may be difficult) and see if the red light goes off. If still no good then you need a new battery. MAY be possible to have someone who sells the unit test the battery or you can test the charger to see if it is supplying the correct output. Checking with the dealer or manufacturer is always an option to consider.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jun 09, 2016 | Garden
24 v ryobi battery won't charge
Minimum FAST charge is 2 hours if it has a fast charge setting. If not, 6 to 8 hours to charge fully. I leave mine on overnight so about 10 hours..
May 22, 2016 | Ryobi Drills
How long for initial charge?
usually for the first charge, most electronics require a 24 hour charge. Unless they come fully charged and ready to use. Check your manual.
Dec 28, 2013 | Android Cell Phones
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Flashing red light batt. fully charged
Flashing red light usually means low batteries. Check the batteries after charging all night with a volt meter through the charger port you should read 26-24 volts dc. If you get a lower reading and you are sure the charger is working correctly then you will need to replace both batteries Hope this helps
Aug 21, 2010 | Jet 3 Ultra Power Chair
Power on Board 450 portable charger light - green flashing
What your seeing there is indicating fully charged.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 01, 2010 | JUMP START SYSTEM
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Oct 03, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Open Questions:
 Grubhead
Grubhead
