Question about Sunfire 300 Two Amplifier
Suddenly my Sunfire 300 x 2 started to HUM, need a Scematic Manual or advice on which parts to be tested
    President:
  • 2,246 Answers
1997 sunfire seat belt light stays on, also light for airbag. need scematic
Check contacts in drivers seat belt before anything else.
Mar 28, 2018 | 1997 Pontiac Sunfire
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
Surround sound doesnt work. When i switch the surround on there is a buzzing/ hum from the speakers. The sub has a hum in analog mode. I try to switch to theater, club, church etc. And still a hum was...
Back up, open the manual and set it up with test tones to verify the hardware before trying anything else. Then onboard FM. Then external sources (according to their manuals).
Hum/buzz solutions are common on the internet. Do some web searching for "audio system hum" to find somethign that matches your symptom.
Sep 01, 2011 | RCA RT2500 System
I have a Sunfire 300 Two, when powered on and connected t the pre amp the output became very low, also the sound is not normal the sound is clipped and towards to high treble. I removed both the RCA cables...
The internal preamp driver is defective. You will need to test the preamp IC and its reaction circuits and then the voltage it receives from the power supply. If the problem is in the power supply you will need to check the rectifiers and the stabilizer circuits.
Mar 21, 2011 | Sunfire 300 Two Amplifier
Sunfire MK II Subwoofer hum. I have a Sunfire MK II subwoofer that hums when it is plugged in (it even hums when no signal is connected). I've tried multiple outlets on different circuits, but hum...
you have a ground loop issue you could purchase a ground loop isolator, jensen makes them for about 40 bucks.I have discovered that if you have cable tv, unplug the incoming cable in your cable box and see if hum disappears.
Nov 25, 2010 | Sunfire True Sub MK II Subwoofer
My dodge durango stop suddenly , the engine was off,tried to cranck it but not starting ,after ten to twenty minutes started .i drove for ten km.then off again. kindly advice
Sounds like your fuel pump is going out. Next time it doesn't start, cycle the key from off to run position (not start) and listen for the soft hum of fuel pump. If it's not there, you need a new pump.
Jul 22, 2010 | 2004 Dodge Durango
Was working fine. started burning ac line fuses and noticed a little smoke. I found a bad light switch going to the ac outlet it was plugged into, which I think has caused this whole problem. removed the...
u have a shorted primary power supply unit on your amp. for linear supply check diodes and capacitors. for smps chek switching transistor or any other switching component. if u have no idea get it repaired by a tech.
Jan 30, 2010 | Sunfire Cinema Grand 200 Five 5-Channel...
Sunfire Amplifier hum
If it works fine with other inputs then it simply cannot be your sunfire. Next time it happens try reversing the power plug on one of the pieces of equipment hooked up to it and see what happens.
Mar 11, 2017 | Audio Players & Recorders
Sunfire 300 Two Amplifier Logo
117 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
