I have a Whirlpool washing machine (awm 5060-600) model that stops working after few miutes of working, I called the repair man from the dealer who checked the machine and told me that the main board controller is damaged. I took out the controller and I took it for test they told me it's seem to be good but check other parts of the machine that might make an overlaod, so I took out the motor but it came with 6 lines and I w'd like to know how to test it.
breddi2
  • 126 Answers
SOURCE: Completely dead
Call manufacturer,they do have warranties that repairmen don't tell you about.
Posted on Apr 23, 2009
SOURCE: Front loader washing machine AWM 6100 Whirlpool
check brushes on motor. how old is machine?
Posted on Feb 01, 2010
caroldon
  • 17130 Answers
SOURCE: Whirlpool washer AWM 5060. First
You must start from the begining to check on the inlet valve and the flow of water to the drum. If the flow is not present check or change valve if the power is present. However if water flows well then check the voltage to the motor is the trigger/switching comes from the controller unit. If absent the controller unit needs a check. If present the motor is faulty. If so the motor starter capacitor is faulty. Look to find this capacitor and change, If the motor is humming this is for sure.
Hope my tip helps.
Posted on Aug 24, 2010
  • 6277 Answers
SOURCE: i have whirlpool washing machine
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 12, 2011
  • 6277 Answers
SOURCE: i am looking for user
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
May I also suggest you try the manufacturer's web site direct?
Good luck,
John C.
Posted on Mar 31, 2011
How do I fix a whirlpool washing machine with the 'door locked' light blinking?
The door lock needs to be replaced. I would recommend using a technician to replace the part just to be on he safe side.
Sep 28, 2015 | Whirlpool Washing Machines
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
Whirlpool awm 9000 I bought a used Whirlpool
The error code F/H for this machine means that the drain pump is blocked. Look at your manual for how to access the drain pump and clean it out. This will resolve your issue.
Oct 18, 2013 | Washing Machines
Whirlpool awm 8103/1
What is the model number of your unit?
Nov 19, 2012 | Washing Machines
Have a whirlpool AWO 3551 washing machine. Door locked light flashes and machine stops at random points in the program. Pump works OK and drains water. Don't suspect door lock module as washer works on...
My daughter had the same problem for about two years. A repair man came out and told her to call the company and tell them she wanted it fixed under a recall. She said the computer board had to be replaced and it was recalled due to a flaw in the machine. The service man came back again after she called, and he fixed it for free.
Jul 16, 2011 | Whirlpool AWOE8748 Front Load Washer
F1 error code
check the FixYa website for other solutions for your model, look for one with 29 postings........
Feb 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Sep 19, 2009 | Whirlpool Washing Machines
Whirlpool awm 759 frontload washmachine
be best to have repair man that done it it can be a long job and not finished 4 someone that never done it
Mar 02, 2008 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
