Question about ASUS A7N8X-X Motherboard
Hi I get one long beep when I turn it on and nothing further happens. I reseated the sound card and unplugged the HD and the Disc Drive and the same thing happens.I've tried googling the beep codes for this board but haven't had any luck..any help will be greatly appreciated. Thanks
    President:
  • ASUS Master
  • 2,246 Answers
One long beep is indicated that your vga card has problem, it like you use onboard vga card
insert pci vga card to your motherboard to change tha onboard vga card
Posted on Mar 19, 2011
On startup nothing happens except beeps about 6seconds long a short break then beeps on a continuous pattern like this, what does it mean is it memory motherboard or harddrive
Hi Nigel,
It is most likely the Memory problem, I would request you to remove the memory and turn on the PC or Laptop, if it's beeps continiously means motherboard is working fine. If it does not beep then it is an issue with motherboard.
For more information on this please click on the weblink provided below.
http://www.computerhope.com/beep.htm
Hope this answers your question.
Jul 06, 2011 | Acer Aspire T690 (AST690UP820A) PC...
When I turn on my packard bell ixtreme 6052 nothing appears yet it does see computer but does not even go to bios and harddrive read light remains on and harddrive is constantly ticking like it's...
This could be lots of things (bad HD, bad Mother board, bad RAM,etc...) first you need to narrow down the possible cause, open the computer, take out every thing that can be unplugged (I MEAN EVERYTHING) RAM, PCI cards, VIDEO cards, all storages HD, CD ROM, etc... just leave the CPU and power supply plugged in, than power up the computer and listen for BEEP's if you hear a series of BEEP's this means the CPU, power supply and mother board are GOOD, than (with power OFF each time) re-install the components you taken out (ONE at a time) to see which device causes the system crash... I've seen a modem card causing a system mall function once rediculous but true...
Feb 20, 2011 | Packard Bell Computers & Internet
My Acer Laptop model is Aspire 4920 and when I switch it on, I hear 3 beep sounds and nothing happens on the screen. The power stays on and nothing happens. Please advise what do to to get it back to...
Hi Friend, The 3 beep codes indicates that the issue is with the RAM (memory) of the system, so i would recommend you to please open the laptop and try to locate the RAM on the system and reseat them (unplug and plug them back in) Try to turn on the system and check if the issue is fixed.
Please let me know if it was of some help
Thank you,
Jan 06, 2011 | Acer (9005210464), (64 MB) Graphic Card
When i turn on my HP Pavilion a1320n nothing happens. it sounds as if it is in standby mode and the fan is runing but the monitor never comes on. i can't get it to the initial dell screen where you can...
id check and reseat memory ram first. it should give you a beep sound for error. if nothing, then check video card and hard drive. you can also remove everything (ram, hard drive, cd or dvd rom) then restart and see if it gives a beep error.
https://kb.iu.edu/d/afzy
May 03, 2017 | HP Pavilion Media Center a1320n PC...
After power on my eMachines C6537, there is no beep sound and nothing shown on screen. The CPU fan and fan in the box are working. The HD drive spin sounds normal. No problem to open doors of DVD and CD...
Disconnect the power cable open the case and pull the CR 2032 battery out for a minute. That will reset the BIOS. If you have no Beep Codes at all the MoBo might be dead. If this were just a video issue there'd be Beep codes. If there's more than one stick of RAM Pull one try to boot then do same with second stick. if there's only one stick of RAM try reseating it.
Jun 27, 2017 | eMachines C6537 PC Desktop
High pitched beeping sound?
hi!
I'm not sure with your beep code.. but here is the list of known beep codes for dell motherboards
Beep codes Possible Causes Solution
1-2 no video card detected Reseat the video card
1-2-2-3 BIOS ROM checksum error
1-3-1-1 DRAM refresh error Reseat the memory card
1-3-1-3 Keyboard error Keyboard connector
1-3-3-1 memory card Reseat the memory card
1-3-4-1 RAM failure on line xxx Reseat the memory card
1-3-4-3 RAM failure on data bits Reseat the memory card
1-4-1-1 RAM failure on data bits Reseat the memory card
I hope it match your beep code..
Please rate this help.. thanks..
May 25, 2010 | Dell Dimension 3100 PC Desktop
Acer Aspire 9303wsmi display problem, 1 long beep, 2 short. HELP!
What you hear are bios beeps. They signal you that something is wrong. These beep's vary by the manufacturer of the bios chip that you have.
You can find out what bios you have by looking at your manual. The common cause for one long and two short beeps is a video problem.
Either the video chip on your mobo is shot, or your video card needs attention.
Hank
Aug 04, 2009 | Computers & Internet
I am trying to fix a power problem on a medion laptop. When you press the power button, the power led lights up but nothing else happen. The laptop does not start. Any help.
When you turn on the system and NO BEEP sound it could be a problem with the system board that fails initialize and boot your system to the operating system. If you hear a beeping sound, you may need to reseat the memory card of your system.
Keep me posted.
Thanks.
Nov 23, 2008 | Medion Computers & Internet
2 beeps & nothing on the screen
Hi Tom,
Please verify the capacity and how many memory modules you have in the system?
If your system won't turn on and get 2 beeping sounds. It is an issue with your memory (RAM) you may need to reseat the memory card. After reseating the memory card (RAM) and the issue persist and i suggest to check also the warranty of your system from your coomputer manufacturer for part replacement.
keep me posted.
regards,
Jeff
Oct 11, 2008 | HP Compaq Presario V2000 Notebook
No beeping, no video displayed.
hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Jun 30, 2007 | Abit LG-95Z Motherboard
ASUS A7N8X-X Motherboard Logo
158 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
