Question about Indesit W 123 Front Load Washer
Door wont open - Indesit W 123 Front Load Washer
    Brigadier General:
  • 6,277 Answers
(try this first!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 19, 2011
1994 lincoln town car passenger door wont open
HELP! How to open "stuck" door - New Edge Cougar Owners
www.newcougar.org > Forum > General > Problems
Mar 9, 2009 - 11 posts - ‎8 authors
Hello all, The driver's side door on our 2000 is "stuck" closed and wont open by key, keyless, ... 1994 Lincoln Towncar w/ 112576 CRUSHED
door help lincoln town car 1994 - YouTube
? 3:04
https://www.youtube.com/watch?v=5yzIfHFU9CI
Sep 18, 2011 - Uploaded by Frank connors
door help lincoln town car 1994 ... owners of Town Cars with hinges that are failing on the driver's door -- and sometimes on other doors also.
Lincoln rear passenger door wont open Questions ... - Fixya
www.fixya.com > Forum > Tags > rear passenger door wont open
Jan 05, 2016 | 1994 Lincoln Town Car
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
May 10, 2014 | liftmaster Chamberlain Garage Door Opener...
98 accord door handle broke door will not open
A non electric door, (which?) wont open,lock works ok, handle wont open the door.
What can I do to fix it.
well telling the door to us would help, and options.
so no electric locks,
there are 2 levers. one inside and one outside.
so you pull the door card (inside door covering)
and look at both locks , the inside pull, its it working?
then look at the key lock cylinder. is it connected still
and last are both connected to the latch mechanism.
one can cycle this latch lever inside the door shell.
if that fails the latch is busted.
all this is covered in the FSM ,why not read it.? (under body)
free , too.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 25, 2013 | Honda Accord Cars & Trucks
Passenger sliding door and rear cargo door wont unlock but other doors will why?
window is an issue by itself.its most likely a bad window regulator or a motor or a switch.the sliding door and back door might be an issue with power door lock actuator.or broken handle
Jun 20, 2013 | 02-03 Caravan 2 Tire Pressure Sensor...
2006 jetta door wont open from inside or outside
link connector broken inside door, Remove door card and repair
Nov 16, 2012 | 2006 Volkswagen Jetta
Drivers door wont open
Chrysler2008 sebring drivers door wont open all other doors and central locking working including drivers door but will not open any suggestions..
Jun 01, 2012 | 2007 Chrysler Sebring Sedan
Passenger door wont open
It wont open from the inside? The outside? or both?. Inside the door panel there is a linkage responsible for opening the doors. If they are not connected then it wont open.
Nov 23, 2009 | 2002 Land Rover Freelander
Driver side door wont open.
You can't.. you've got to open the door. sorry.
Jun 26, 2009 | 2001 Hyundai Tiburon
1990 honda drivers door wont open
door latch is jam the last time i change one took 1and a haft just to break that stupid door lacht you have to be carefull you have to pry to door panelon top its not easy good luck pierre
Jul 29, 2008 | 1990 Honda Accord
Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Jul 19, 2008 | Washing Machines
Indesit W 123 Front Load Washer Logo
90 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
