Pc description as below-
mother board--intel chipset-i810
prossecer--celeron-1100 mgh
ram-256 mb
o/s-windows 98.
when i conect transcend pen drivewith my pc for adio and video play pc was hang .
when i play adio and video from hdd with any media player also pc was hang.
please sent me some solution to solve this problem.
**-for pen drive i instal the driver.
Hi my name chandra sekhar i'm hardware & networking engineer .sir i did restore but my laptop is still problem after formating my laptop the problem still like that only problem i'm fasing wat to do give me any solution to solve this problem sir
thanking you sir.
and my e-mail id [email protected]
Hello Ramkrishnasa,
You are getting this problem not because of ur pendrive as you said that Same problem is occuring even if you are playing audio or video files from HD.
The problem would be occuring because of:
1. missing of codec.sys files that enables ur system to play any video or Audio files.
2. Missing of ur system media *.dll file.
3. It can also be caused due to viruses.
You need not to worry about this thing. Follow the following steps to fixya problem:
1. It is recommended to restore ur system which will fix missing media system files or any error that leads ur system Hang.
2. To Restore ur System: Go to "Start"-> "All Programs" -> "Accessories" -> "System Tools" And then Click "System Restore".
3. You'll be able to see the wizard to restore ur system.
4. Now select the redio button to choose different restore point.
5. Select the restore point, you suspect that ur system was functioning well at that point. You can select different resotre point by scrolling the calender.
6. select the restore point and click Next to restore ur system.
7. System will restart automatically to restore ur sytem.
Thanx
-Romy
Hi I m sunil
U can clean up ur pc by following:
1-go to start-run
2-write temp-ok
3-write recent-ok
4-write %temp%-ok
And
5- Write MSconfig ok then Startup Disable then Restart PC
ur pc is now clean and full speed
Ibrahim surchy-kurdistan region-iraq
u can clean up ur pc by following:
1-go to start-run
2-write temp-ok
3-write recent-ok
4-write format-ok
My pc stop working when i restart i do delete all temp file,and %temp% scan my computer with escan antivirus,but stil now my system is not properly working please give me a solution thanku
Whenever your system is not working properly may be problem regading virous and your pc configuration.love cost memory and processor.Delete the free rough from windows prefech directory.and set the your computer on best performence.
And keep virous free.
Dear chandu first fall boot restore cd boot to pc, after that u will take to backup and antivirous start then format to pc. it will work fine javed hardware/network engg mumbai
when I play a video on Windows 98 my computer hangs or it plays for a
minute and then hangs.
whe i was on my computer it was hang
