Question about KitchenAid KBNU367TSS Gas All-in-One Grill / Smoker
I have a KBNU367TSS and I am having problems with 3 of the 4 ignitors. Two of them will not work at all and one of them gets red but not hot enough to ignite the gas. The rear burner ignitor works fine. The cost for each new ignitor from Kitchenaid is like $90.00 each. Anyone know what the problem is or where I can find the part for less money. Can this problem be fixed without replacing the ignitor? Any help would be appreciated.
    Champion:
  • 274 Answers
One problem with glo plug ignitions is the loss of voltage across the glo plug. Each glo plug has to have the correct amount of current to get hot enough to light the gas. If the current is to low, the plug will glow, but not light the gas. You have to open the grill up and check the wiring, etc for shorts, bare spots in the wires insulation, etc.
Posted on Mar 20, 2011
Starts and runs for a few minutes and then just quits?
Hello Larry;
My name is Peter. I am a retired field service appliance technician.
You have not provided a model number so I do not know if you have an electric or gas dryer. Your model number may be on a label when you open the door.
In general:
1.) Air Flow Problem - Over time lint accumulates in both your hot air distribution manifold as well as you wall air duct. This will shut you down.
2.) Week Ignitor (Gas Dryers) - The ignitor in a gas dryer will glow red. The ignitor can glow red yet not have enough power to open your gas valve.
3.) High Temperature Thermal Switch or Fuse - In both electric and gas dryers you have a high temperature thermal fuse or switch. In either case, when this component is bad and reads any temperature, high or low, it will shut you down.
That is all I can tell you without knowing your dryer model number.
Jan 23, 2015 | Dryers
Electronic ignitors don't work
Did you try changing the battery? Usually under the ignition button is a aa battery that make she switch electric. Check that out.
Apr 17, 2013 | KitchenAid KBNU367TSS Gas All-in-One Grill...
Oven has worked on and off for the last year, now doesent work at all, i have the igniter exposed and it is glowing red, you do not smell gas at first but after about 2-3 min you begin to smell the gas,...
If your unit has a separate gas valve for the oven burner, that would be my first guess. But I would also check to make sure that the thermocoupler was not corroded, coated or defective.
Jul 15, 2011 | Ovens
Smell gas before oven ignites
usually a problem with the oven ignitor not getting hot enough to ignite the gas. if ignitor has a dull orange-red color to it, probably should be replaced. a new ignitor should glow with a yellow to whitish color indicating it is hot enough to ignite the gas.
Jan 09, 2010 | Kitchen Ranges
Top broiler igniter lights, but no gas is coming
The ignitor should glow almost white hot. If it is just red hot it may not be drawing enough amps for the valve to read and not allowing it to open and releasing the gas. It should pull 2.5 - 3 amps for the valve to open.
Aug 04, 2009 | Kitchen Ranges
H400 WILL NOT LIGHT FAN WORKS
If your ignitor is getting white hot it is hot enough if it just get's red hot it may be low voltage. If this is not the problem than it has to be something keeping the gas from getting to the ignitor. If the ignitor is steaming then you may have a deeper problem with sweat on the exchanger wich may mean a venting problem. But the end result of this would be rusted or burnt burners and you will need to pull them and check to make sure they are letting gas flow correctly. Good luck.
Jun 25, 2009 | Hayward H Series Pool & Spa Heater 400k...
Burner flame shuts off during use and then you smell gas
all ovens, when they reach temperature they go off and on to kip the temperature, but if you smell gas the oven ignitor needs replacing, the ignitor gets red hot to ignite the burner ,but when ignitor does not get hot enough, it will have a delayed, that's the reason you smell gas.
Dec 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Oven takes a long time to heat up
your ignitor could be going out. the ignitor has to get hot enough in order for the gas to turn on and heat your oven. if your ignitor is going out, sometimes it doesn't glow hot enough for the gas to turn on, or it could be that is takes longer than normal to get hot enough to turn the gas on. I would replace the ignitor and that should solve the problem. Joe
Nov 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gas range FGF337
The ignitor should be almost a white hot color very bright . If it is orange or kinda reddish, the ignitor probably isn't getting hot enough to open the saftey valve. you could check the amp draw on ignitor , but most of the time if the ignitor isn't glowing bright almost white , that is probably the problem, besides that if and only if ignitor was good then i would look at the saftey valve. My money is on the ignitor.:)
May 19, 2008 | GE JGBP28 Gas Kitchen Range
Oven wont start
The control sends voltage down to the ignitor, the ignitor glows red, when and if the ignitor gets hot enough it opens the gas valsve to let gas in which is then lit by the ignitor.
If ignitor glows either the ignitor is bad or the oven valve
If the ignitor does not glow then either the ignitor is broken, the control is not sending voltage down, or the oven valve is bad and not sending voltage to the ignitor.
In most cases it is the ignitor which is the cheapest of the three parts
Oct 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KBNU367TSS Gas All-in-One Grill / Smoker Logo
309 people viewed this question
Top KitchenAid Grilling Experts
Paul Carew
Paul Bade
Bill Boyd
Are you a KitchenAid Grilling Expert? Answer questions, earn points and help others
