Question about HP Officejet 5610 All-In-One InkJet Printer
Fax Modem for HP G85 ALL In One
I recently had a lightning strike close to my home. Since then my fax modem as quit working. The phone lines had to be repaired to the house and are now working. I believe that the modem is toast. I have an HP # of C6735-60009. How do I find a replacement part?
  • mjanes22 Aug 08, 2008
    I have an officejet 6110 all-in-one and after a lightning strike the power went out and now the hp officejet won't turn back on. I have checked the power source it appears ok. The unit is plugged in.
  • dbear4nwa May 07, 2009
    I have the same problem. The printer work fine but the fax does not. Also from a lightning strike that took out my phone line too. Looking for an answer to solve the problem without buying a new printer. I have the HP officejet 6310.
Eer
Posted on Aug 18, 2008
  • 20 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
a2
Posted on May 27, 2009
Trying to connect fax with my optimum (which is a triple play package) I also have wireless. The Wall jack cord is going directly into the modem. How do I connect the fax?
Your Optimum modem is acting the same as the phone company's input line to your home. The cord that goes from it to the wall jack is actually powering up all wall jacks it the home. You can:
  • Use any available wall jack in the home to cable up to the fax.
  • Split the output signal from the Optimum and connect to the splitter (may not work).
  • Run the Modem output to the LINE connection of the fax, and the EXT output of the fax to the wall jack (may not work)
Jun 28, 2015 | Office Equipment & Supplies
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
HP printer 7310. Fax want work. We had a storm but I got a new printer to wall cord and copied ok. Today, the Fax want work has error) Ox886a7a16. Can you help? Lights just blink..and all is stated on the...
If you got hit with a power surge from a lightning strike, it can come into a device from the AC outlet OR the telephone line. I suspect the modem (needed for FAX) section of your machine is fried. If this is in a home office, you should really have a 'whole house' surge protector installed to avoid business interruptions.
We have the Intermatic IG-1300-2T; for 4 telephone line protection it is : IG-1300-4T
Simple to install in the main breaker box and both include 5 years of insurance for losses of $10,000.
You can see them here:
Intermatic Surge Arrestors
The 4 line model (4T) is currently on sale.
Sep 06, 2011 | Office Equipment & Supplies
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
Had a very close lightening strike in my back yard. Everything was connected to a sorge protector. It fried my Cox Cable modem, my telephone and the #2 phone jack on my all-in-one. Bought new phone and...
Yes it is likely the HP All In One is damaged - I suggest you put your money towards a new All In One as a repair most likely would not be a cost effective solution.
Jun 09, 2011 | HP OfficeJet J4580 All-In-One Laser...
MY HP Fax machine won't send fax, sends error what is wrong with the machine it's a 2007 Model 1040. when I am sending the fax after one page it beeps a lot and then feeds the rest of the pages. then on...
You either have a noisy or Digital phone line.
Have your phone company check the line.
I have NEVER seen a bad fax modem, unless it was fried by a lightning strike.
Apr 28, 2010 | Office Equipment & Supplies
My 2003 server sees the modem v.92 fax, but i can not seem to use it. I tryed to reset it, powered off and back on, reinitialized it but nothing seems to work.
A lightning strike to the phone line can kill the line interface while the computer interface is still ok. This would produce the symptoms you describe. If you can open the modem, look around the phone line connector for burnt components or burning on the board.
This might also stop the phone line from working when the modem is connected, ie another phone on the same line will produce no dial tone with themodem connected.
If this is the case a new modem will be the cheapest way out of this.
Apr 20, 2010 | USR5686E, US ROBOTICS 56K V.92 EXTERNAL...
Incoming faxes
Do you have a distinctive ring pattern in the same phone line
If no then you need to get a distinctive rig pattern from your service provider, which will differenciate the type of rings for phone and fax.
If you have a distinctive ring pattern make sure which one it has single rings, double rings, triple rings and double and triple rings.
To enable> First make sure auto answer in turned On
In setup/Menu go to > Rings to answer and set it to 5 or 6, and make sure the rings to answer in you answering machine set to 4(Always Should be lower then you rings to answer in the fax)
In Advance Fax setup> Then Ring pattern should be setup for the one which you service provider as given either double or triple Rings>
And the go to tools and run fax test and check what has failed
Aug 28, 2008 | HP Officejet 5610 All-In-One InkJet...
HP G85 auto-answer
yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
Jan 18, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Modem taken out by lightning
Hi Dave
Are you aware that if modems or other components get shot with lighting that you vwery lightly to get intermittent problems on the machine thereafter. That product is probably insured on your house or business insurance. I would strongly recomment replacement and if you depend quite a lot on the fax get a seperate machine.
Sean
Nov 28, 2007 | HP OfficeJet t45 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
126 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
