Question about Janome 1600P-DB Mechanical Sewing Machine
Tension I am having the same problem as listed for this machine. I made the mistake of taking the tension adjustment disc off and am not sure if I have itt back on correctly. Does anyone have a diagram or a correct listing of the way the parts are to go back on the tension adjuster?????? I am getting lots of loops on the bottom and lots of thread breakage from the needle.
  • Janome Master
  • 1,388 Answers
27 - Complete Tension Unit
28 - Setscrew TP 3 X 6
29 - Hexagonal socket screw 4 X 6
There is no exploded view for this component, so if you cannot confidently restore the unit, suggest seeing a technician, and the next time you take something apart, use a camera for reference, and lay components out carefully as they come apart.even write notes for yourself.
Hope this is helpful, it is the best image available in the Janome Manuals.
Posted on Aug 02, 2008
My Elna sewing machine is sewing very loosely and it is very messy on the bottom side of my material, why?, and how can i fix it?
When your bottom thread is messy it is the top thread needing adjustment. Your machine may not be threaded properly and the thread may not be sitting correctly between the tension discs.
Check to make sure your machine is threaded correctly.
Check thread between the tension discs.
After checking, adjust the tension (tighter) and do a test. If it is still messy add some more tension and do another test.
Jul 10, 2017 | Elna Sewing Machines
Tension from bobbin to tight how do I adjust
Hi, The tension is a factory setting that should not be normally adjusted. the lower tension should be fairly stable.
if you happen to have the "bird nesting " happening on the bottom of your project that is caused by the top tension being too low or bypassed by mistake, or the take up hook not threaded on the top. If you wan t to email me directly at tenorrichard@aim.com i would be happy to try to help.
Apr 27, 2015 | Sewing Machines
I have a new singer 7469 confidense quilter - regardless of thread, needle, and material (all being appropriate for one another) the upper tension always pulls the bottom thread to the top. I have tried...
1. Adjust the bobbin tension tighter. The tension you are trying for is to be equal to the top tension.
2. The top tension should start at about four. When you are threading the top do it with the pressure foot up.
3. As you are threading the top give little tugs to check for snags.
4. When you thread the tension control make sure it goes through the tension disc.
5. After you have threaded (except needle) lower the pressure foot.
6. Give a tug to see if the thread will move without excessive resistance.
7. Thread the needle and try sewing.
Feb 28, 2015 | Singer Confidence 7463 Computerized Sewing...
How do I adjust the tension on brother SE-350?
Before you go adjusting tensions, make sure your upper thread is threaded properly. Always thread with the presser foot in the UP position so the thread can slip easily between the tension discs. Also make sure there are no wraps around the thread spool spindle.
Be certain that you have the bobbin properly inserted as well.
Once you are absolutely certain that there is no issues is threading. The tension is adjusted by a wheel on the top of the machine. Left to loosen, right to tighten the tension.
Jul 04, 2014 | Brother SE350 Mechanical Sewing Machine
The tension dials on my Bernina 2000DCE overlocker is not working, no matter where I turn the dials, the tension remains the same, a mess! Any suggestions?
Possible problems are lint between the tension discs. You can clean this with a business card. If the tension discs are not meeting together you must take the machine apart to adjust the spring tension. If all the tension discs not closing. If that is the case your presser foot tension release lever may be stuck.
Oct 13, 2013 | Sewing Machines
Have a DDL-555 bought used. The thread bunches up on bottom.
thread loops on the bottom is a sign that it isn't threaded correctly or the tension isn't set right.
Industrial machines tend to do some strange threading procedures. Are you sure you have it threaded correctly? Two of the machines I've had required that I do a 360 around one of the tension discs. I would start there.
Also some industrial sewing thread is waxed and that wax can cause you issues in between the tension discs. Raise the presser foot and take a piece of sturdy material like canvas or denim and "floss" between those discs. It will help remove wax build up that could be keeping your tension discs from working properly.
Nov 25, 2012 | Sewing Machines
I have a Husqvarna Viking 100. How do I adjust the bobbin tension?
U do not recomend that you adjust the bobin tension, what do you have the top tension set at? It should be between 3 and 4, have you put in a new needle? Also, check to make sure the thread is 'seated' right between the tension disc, if you stil have a problem then your machine is out of time.
Sep 07, 2010 | Husqvarna Viking 1
LOOPS WHEN SEWING
This is a top tension issue, you need to check two things,
-make sure you thread the machine with the pressure foot up ( this allows the tension discs to open up so you can pull the fabric away from the machine with the foot up and allows the thread to get to bottom of the tension discs)
-make sure your tension settings are set to the medium setting. (Usually 4 or 5)
If this still does not help, then turn the top tension knob up (from 5 to 6,7,8,9....)
-If that still doesn't do it, your probably need the tensions reset, and your local family sewing store will be able to assist you further.
-Chris
Jun 06, 2010 | PfaFF Quilt & Craft Pro 7530
Europro x
There is probably a thread broken off inside the tension discs.To remove it ,adjust the tension knob to 0 tension, and raise the presser foot. Spread the tension discs a part with a small screwdriver and blow some canned or compressed air through the discs.You should see some thread or lint come out of it.
Rethread the machine,adjust the tension back to 5 and test the tension by pulling on the thread near the take up lever. When the foot is up there should be almost no tension. When the foot is down you should have tension.
sewman7
Jul 27, 2008 | Sewing Machines
Breaking thread
1. Make sure you are using the correct needle and thread for type of fabric and it is installed correctly. Make sure bobbin is threaded evenly. 2. Tread path - make sure the machine is correctly threaded. Then, with your finger, feel for burrs, nicks or roughness on any metal parts that contact the thread. Open the slide plate, remove the bobbin and inspect the bobbin case and hook. Remove the needle plate and examine the needle hole. Sand any rough areas with fine emery paper and blow away grit. If burrs or nicks remain on the needle, presser foot, needle plate or bobbin case, replace them with exact replacement parts, if they remain on the thread guides, take-up lever, bobbin hook or tension regulator, take the machine for professional service. 3. Loosen thread tension by adjusting tension dial. 4. Clean feed dog, bobbin case, and tension discs. Unplug the machine. Use a small, stiff brush to wipe dirt and lint off the machine head and the needle bar area. Raise the presser foot and the needle to the highest position, open slide plate and remove the bobbin and needle plate. brush away dirt and lint from the feed dogs and bobbin case and remove any tangled thread with your fingers. Use a soft cloth to clean between the tension disc on the tension regulator. 5. Also check tension on presser foot
Dec 31, 2007 | Consew 206RB
Janome 1600P-DB Mechanical Sewing Machine Logo
130 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
