Question about American Standard Heating & Cooling
I have a small house with a outside package unit American standard (Trane) Model# WCM030F100BB, italso says BAYHTRN110A. When I select cold from the off position on the thermostat it immediately pops the breaker. It is heat pump equiped and if I select heat it also pops the breaker without hesitation. If I select emergency heat, then fqan to on from auto and then select heat with the top switch of the thermostat it heats the house fine using it`s electric strips. The manufacture date is 01/1996, Does it sound like the compressor is shot and is it worth it to replace the compressor? If not can you give me a ballpark cost on a new or used outside package similar to this one (cheapest I can get away with) I think 1 to 1-1/2 ton would do fine, Thank You, Jeff.
    Master:
  • 414 Answers
I would check the outdoor unit, Trane uses "Sump Heaters" on their compressors
and when one fails it will blow fuses at the disconnect or trip breakers.
The sump heater is a small metal pencil sized item at the bottom of the compressor
with something that looks like lamp cord going to it. Also when the start capacitor
fails it will exhibit this symptom. Look at the can shaped items inside the cover
If they are leaking, or bulged this may also be the problem.
(with the breakers off to everything including the inside unit to prevent shorting
the transformer)
These are the most common problems and the parts are less than 20 dollars each.
I service 155 trane units at my properties.
hope this helps.
Posted on Mar 19, 2011
I have a American standard ac model 7A0018-60A100A and would like to know the model no. of the condenser fan motor so I can replace it
All you need to know is that it is a 1/4 hp, 825 rpm. 1/2 inch shaft. That is if you are going to buy an after market motor. I have had to make new mounting holes when using after market motors on trane systems (just the way trane is) but not a problem. If you're getting it from trane you would only need the model number of the condenser.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 14, 2017 | American Standard Heating & Cooling
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Trane XB80, no heating, limit circuit open
Sometimes these can be reset by gently taping them on the floor. Can be caused by not changing your furnace filter.
May 18, 2014 | Trane American Standard Trane American...
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
When I turn my electric a/c to heater it makes a repeat tac sound quite loud. An a/c tech opened the metal box on left side where the fuse is located and said that the board and relay needs to be replaced....
It sounds like the tech was referring to the blower relay. The blower relay on this unit originally had a small circuit board mounted to it. It's only purpose was to allow for delay off-time of the blower at shutdown. In other words, once the command for the blower was de-energized, the blower would continue to run for approx 90 secs. This is something that is optional. It does slightly enhance the operation of the air handler; however, it is not something that is absolutely necessary. It is possible to replace the relay with a standard type blower relay; however, it will require it small bit of re-wiring. Your service tech should be able to help you. I would recommend that you use the service tech. This will prevent possible mis-wiring which could damage your blower motor (very costly) and most service companies offer a 1 year warranty on the parts. However, if you are going to try to do this yourself, the part can be obtained from Grainger or an Air Conditioning Supply House for approx $20.00. The blower relay is a 90-340. If you purchase it from a contractor, it will be approx double.......every business marks up their product, it's how they make money.
I'm attaching a link to a site that has the specs and a wiring diagram for your air handler.
I hope you find all this information helpful and I wish you luck in your endeavor. :-)
http://74.125.155.132/search?q=cache:7UZFtDiHEyQJ:www.trane.com/webcache/un/split%2520system%2520air%2520handlers%2520(ssa)/product/22-1222-03_10011993.pdf+Trane+model+TWV-&cd=3&hl=en&ct=clnk&gl=us
Feb 26, 2010 | American Standard Heating & Cooling
Inside Electric Furnace/Air Handler Not Working. Please help!
ok this can be simple or tricky is the breaker that trips the same size as the one in the breaker panel 2.look in the unit itsself see if there r breakers inside the unit there usually are and they might have tripped it might be as simple as flipping a breaker but the problem with the breaker tripping is what concerns me now it may just be undersized or getting weak and finally crapped out get ur meter and flip the breaker on and see if u r getting power to the unit if ur not u have gott a breaker that isnt letting power go thru now if u have power u might have a bad blower motor turn the unit on and calling for the fan on if the fan doesnt start try spinning the blower by hand now if it starts then u probably have a bad capacitor they r usually mounted on the side of the blower housing it is oval and its gonna be a 5mfd(microfarad) or 7.5mfd and that couldve been what was kicking the breaker now if the blower is stuck and it wont turn or its very hard to turn then make sure the blower wheel hasnt slipped on the shaft and is rubbing up against the housing if it is just loosen the set screw and set it back even and tighten it back up now if the wheel is free and its still hard to turn then u have a bad blower motor its not a big deal to change out and not real expensive if this dont help hit me back and well walk thru it hope this gets lil momma and the pets warm have a good day
Feb 26, 2010 | Heating & Cooling
TRANE 1984 Home A/C Where are How to Clean Coils inside House
the best thing to do it with airhandler shut down at breaker. 1st soften dirt and crud with 409 or different brand. 2nd take a wire brush and clean in up and down motion following the fins on coil.3rd rinse with spray bottle . this is the best you can do without coil removal.
Jul 02, 2009 | Heating & Cooling
Need schematic for an American Standard A/C Model number 7A0030A1
American Standard and Trane are the same thing. The diagram you want is not complicated at all. Just straight cool unit. American Standard does not put low or high pressure controls on unit. You can get diagram on line At American Standard.com. Just what do you need to know? Very basic unit.
Jun 11, 2009 | Heating & Cooling
Heating & Cooling Logo
192 people viewed this question
Top American Standard Heating & Cooling Experts
Craig Butler
Craig Butler
Tim Whalen
Mack Baxter
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
