Question about Water Dispensing & Filtration
Our house water pressure drops way off when our Kenmore Model 625.348571 is in use. When I select by pass the pressure returns to normal. I have back washed it a couple of times, and also used the Sears water softener cleaner a couple of times but no change. Is there a screen or something at the bottom of the resin tank that could be clogged? Would it be worth pouring the beads out to clean that area? Any other suggestions? thxs
    New Friend:
    Problem Solver:
  • 10 Answers
Yes, there is a screen, but it is unlikely that it would be clogged. If it were the backwash would've cleared it. Most likely the problem is in the valve head.
Posted on Aug 28, 2017
zeusfaber
  • 247 Answers
SOURCE: Bleach and fabric softener dispensers full of water
This is a problem common to virtually all front-loaders. Pull the dispenser drawer right out (it is designed to come right out - you might just need to give it a bit of a jiggle to get it past the stop) Remove the cover/caps from the drawer (sometimes this is a snap-on cover over the back of the drawer, sometimes a top-hat shaped cover over the siphon spigots). Give everything a thorough clean off with hot water (scrubbing with an old toothbrush helps), then reassemble. A.
Posted on Jul 16, 2007
  • 4 Answers
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
SOURCE: kenmore elite washer model 20952992 pouring water
We had the same problem. The bleach dispenser tray is located on the drum below the bleach storage pan. The dispenser tray has very small holes that were plugged by rust from the hose clamp that attached the dilution water supply hose to the bleach storage pan. I removed the top of the washing machine to discover the problem, but it may be solved by attaching a flexible tube or small hose to the end of a vacuum cleaner hose and cleaning out the dispenser tray. There is room between the dispenser tray and the storage pan and is located in the front right corner.
Posted on May 14, 2009
  • 98 Answers
SOURCE: Spots on clothes after washing
Put another filter on before the washer. Try to find out if it is in the hot water or the cold. If it is the cold try a filter. If it is the hot, replace your hot water tank.
Posted on Jun 06, 2009
  • 15 Answers
SOURCE: not sure what to do after using self cleaning gas stove
The self cleaning is used to loosen grease only, when it has ran its cycle you must take a damp coth and wipe away the excess. As for the window it is best to use something like vinegar , just dampen a cloth and clean the window. Rember, Damp only no excess water
Posted on Nov 10, 2009
What is the lowest water pressure and flow for a admiral washer model #atw4676bq1?
When the water pressure is low, the water flow is just less.
When the diverter opens, it lets whatever water is there pass through, So there just has to be enough pressure to lift the water from the water input past the top of the tub to where it sprays out,
I grew up in a house with its own water system. When the water pressure was low, it just took longer to fill the tub. As the pressure dropped the flow became less and less, Even at a dribble water continued to flow until the water level switch turned it off.
Mar 03, 2018 | Admiral Washing Machines
My kenmore oasis he model 110.27086604 works until it gets to the rinse cycle which is at 17 min to be done, then it stops and shows a lf error, do you know what that means?
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 26, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
My Kenmore Elite Oasis He washer has a problem with getting stuck when it's in Normal wash at the 17th minute in Rinse where the cold water will not dispense. It goes around slowly for a long time until...
Sep 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I have a kenmore elite top loading washing machine model number 110.2706, 2707, it keeps giving us the message LF, what does this mean?
Apr 25, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis Elite Type 580 flashing LF
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Mar 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
We have a Model 587.1440*, 587.1441* Kenmore dishwasher. I had turned the water off to the whole house when we left for vacation and openned one faucet so the water pressure would be off the house while we...
First, have you run it long enough to purge the air from the dishwasher line?
Secondly, the solenoid valve for the water inlet may be stuck due to no pressure on it while you were gone. Tapping it with something light like a wrench may jump-start it.
Charlie
Aug 14, 2009 | Dishwashers
Lost water pressure on house
it is normal to loose pressure from the filter it must have very small holes in it for the water to pass threw so it can trap dirt and particales from both well and city water. it is normal for it to cut back on pressure, it will cut back more and more as it catches the things that you are filtering out. what you might want to do is filter your drinking water only, under your sink .dont try shower and outside faucets. and you wont have to replace it as often. well good luck and good day to you... sawdust46
Jul 03, 2009 | House Brand Aqua-Pure AP102T Whole House...
My kenmore is rading lf at 17 minutes.
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
High (incoming) water pressure in house
You only have to regulate the incoming valve in your wall (to the washer) to have safe pressure.........don't see any reason why you can't do this.........& get on with your tons.......
Nov 27, 2007 | Kenmore 44102 Front Load Washer
Water Dispensing & Filtration Logo
2,615 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Larry
Tom Chichester
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
