Question about De Dietrich DME101 1000 Watts Convection / Microwave Oven
We can set the mode using the turn/select knob but then the programme won't start. It isn't in child mode. None of the modes will operate even though all can be selected. Many thanks
How do I disable the child lock on a Sharp R-891 Microwave?
It looks like from the "Home" Screem press "Information Desk" then "Useful Information" then "Child Lock" then "Set The Lock"
If you don't have a owner manual you can view online or download one here. Just put your model number in the search box
ManualsLib Makes it easy to find manuals online
Good Luck,
John
Sep 10, 2016 | Sharp Microwave Ovens
Microwave is in Lock -- how do I unlock it?
" 1. CHILD LOCK
The Child Lock prevents unwanted oven operation
such as by small children. The oven can be set so
that the control panel is deactivated or locked. To
set, touch Custom Help, the number 1 and Start/
Touch On. Should a pad be touched, LOCK .
.. ON will appear in the display.
To cancel, touch Custom Help and Stop/Clear. "
Also, to find manuals........
Oct 03, 2014 | Sharp R-1480 Microwave Oven
Microwave comes on in cooking mode with the door closed when plugged in. The Clear/Off button does not turn off and we have to open the door to turn off.
I have a hunch the microwave panel is going into Child lock mode and preventing you from operating the clear/off function. Not sure which is the middle switch that you replaced. I would suggest you give the panel a good wipe with a clean damp cloth to remove all grime etc. Before selecting the start/pause button press the Clear/off button for 3 secs and see if the L (lock) shows up on the display. Next press again for 3 secs to see if L goes away.
This way you have confirmed the panel is not in lock mode before you start next operation. Provide your observations in the comments section so that I can assess what the next step should be.
Aug 14, 2014 | General Electric PEM31SMSS 800 Watts...
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
Child mode off panaso inverter
reset the microwave. Disconnect from power cord, by 1 minute, and try again.
God bless you
Jul 05, 2013 | Microwave Ovens
Sharp Microwave on "Lock" and
The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
Mar 08, 2011 | Microwave Ovens
I am not knowing how to operate the microwave tobake a cake...i am unable to set the time after i select the cA mode
The baking mode for cakes relies on wet weight of the mixture, not time as there is a humidity sensor that sorts that out.
Press the CA button to select Cake and the weight button to select the weight then start.
Jan 02, 2011 | Electrolux Microwave Ovens
Cobart Automatic Meat Slicer is not working on Automatic mode
To operate the slicer in Automatic mode . . . Rotate the Speed Selector Knob to the desired speed; make sure the Carriage is in HOME position (all the way forward); make sure the Lever is on the Manual position (pointing down); turn the slicer on; start the carriage drive unit by rotating the Lever to the Automatic position (up and to the right). Either of the two speed selections can be used to begin Automatic mode. The speed can be adjusted at any time by rotating the Speed Selector Knob. To stop the drive unit, rotate the Lever down and to the left - to the Manual position. ------------ If you slicer is set on proper automatic mode and still not running on automatic mode then the problem relates to internal motor or the selector knob. But try reset before this. Push the reset button underneath the slicer near the right-front foot if the carriage motor overloads. The reset helps in some problems.But if its not helping then internal connections of selector knob has to be checked.Of the same with motor,the connections of motor to the selector for automatic mode has to be checked.---------------- This will help.Thanks.Helpmech.'
Dec 15, 2010 | Microwave Ovens
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Child lock on and don't know how to turn it off
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
The manual says to turn it on or off, hold the Cancel button for 5 seconds until you hear the tones.
If you still have trouble after that, the surge may have done some damage, even though the unit has built-in surge protection.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 08, 2008 | Whirlpool MH3184XP Microwave Oven
De Dietrich DME101 1000 Watts Convection / Microwave Oven Logo
Top De Dietrich Microwave Ovens Experts
William Miller
William Miller
ray gallant
Melissa Martin
Melissa Martin
Are you a De Dietrich Microwave Oven Expert? Answer questions, earn points and help others
