Question about Sunbeam Microwave Ovens
Sunbeam kitchen scales Model FS7800 not working shows message "un5t" and "out2" alternately. Battery checked and good
Plate wheeled support broken
You will need to go to Sunbeam to get that part, if it were a plate easier to find. ebay is a very good source for microwave parts, also check out a microwave repairman.
Mar 08, 2012 | Sunbeam Microwave Ovens
I need a glass top for the lid of a Sunbeam perculator ap-20 deluxe
I believe AP Wagner is the only source for Sunbeam replacement parts. Give them a call at 1-888-APWAGNER (1-888-279-2463)or find them on the web at http://www.apwagner.com/. You can also contact Sunbeam directly at Appliances - Kitchen and Irons (800) 458-8407.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Sunbeam Microwave Ovens
Is there any chance the manual is still out there for the party grill 870 ?
Look on the bottom of the unit for the Product code number. Then use that number and check here:
http://www.sunbeam.com.au/Pages/Support/ManualSearch.aspx I tried 870 and it did not work. If I remember correctly this is a 1950's era grill. (just may not be a manual out there)
If you can not find it there use this contact link:
http://www.sunbeam.com.au/Pages/Support/ContactUs.aspx
and ask them for a manual for your Model 870 party grill.
A search of E-bay did not reveal a manual but it did show the Grill for $9.95.
http://www.hammerwall.com is usually the other source for kitchen appliance manuals and it was not listed there either.
Good luck and thanks for choosing FixYa,
Kelly
Apr 03, 2011 | Microwave Ovens
My Sunbeam coffee machine model EM900 twin thermolock cafe series.Was leaking water around group head . Have replaced the grouphead seal but still leaks infact worse My machine is 7yrs old but in good...
I have a Sunbeam twin thermoblock Im having trouble with my steam wand I im not getting much steam out for the milk to warm up try to clean it with a pipe cleaner can you give me an advise how to get it woking
Feb 01, 2011 | Sunbeam Microwave Ovens
Microwave Model 40180089700 shows "5E"
You have an error code and probably for good reason. maybe a switch is bad to keep out radiation for closing the door or what ever . If you don't know about these things don't mess with them! They are very dangerous and it can radiate you with out you knowing in some instances. Not worth messing with ,too dangerous for the unknown guy!!!!!
Jan 12, 2011 | Kenmore Microwave Ovens
Have a Sunbeam-Oster Bread Maker Model 4810, Style BB-100. I haven't used it in awhile and when I plugged it in there is nothing showing in the display. Pressing the "Start" button also yields...
open the unit and check for an internal glass fuse on the control board,sometimes when they sit for a period of time the fuse wire deteriorates and breaks or by the initial current surge it can burn thru too
Jan 07, 2011 | Sunbeam Microwave Ovens
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
Door not opening
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
To order parts, refer to the Sunbeam number in your manual.
Aug 19, 2008 | Sunbeam SBM6500W Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
