Question about Whirlpool Dryers
My Whirlpool AWZ8577 tumble dryer has developed a fault, after a cycle there is little water in the top water container and when you remove the heat exchanger the water floods out of this area. It appears that the water is not emptying into the water container.
    President:
  • 3,074 Answers
Find the drain hose as it is clogged with lint, clean out and it should fix the problem. Tim
Posted on Mar 19, 2011
WHIRLPOOL AWZ8577 dryer will not heat up. Is there a thermostate reset or online fuse with this model, any help will be appreciated.
More likely the heating element is gone. Purchase a replacement and install it. You will need to open the back of the dryer to get to it. Replacement is simple.
Jan 05, 2012 | Dryers
I got a Whirlpool AW Z 865 dryer. It is a condenser dryer and the water is not going up to the collecting bucket, but remains below and then leaks out and floods the floor when I open the little pull door...
I had a similar problem with a Whirlpool AWZ 8578 Tumble Dryer. The solution was to clean the fluff out of the rubber grommet in the drain hole under the left front of the condenser. Then the water from the condenser could run into the collection container underneath.
Nov 25, 2010 | Whirlpool Dryers
WHIRLPOOL AWZ8577 somehow my dryer is getting the water out through the little tube at the bottom of the back. I want to know how to make the machine collect the condense water into the container again...
whirlpool awz8677 i am getting the same problem with my brand new dryer. Getting water coming out through the bottom front and back. Anybody know how to solve this problem? Thanks.
Oct 23, 2010 | Dryers
I have an ASL70C Ariston tumble drier that suddenly has stopped emptying the water into the water tray.the clothes are still drying but where is the water going
Einy Lane -- Water Drain question -- If your dryer is installed next to a drain the water can be plumbed into this drain. This does away with the need to empty the water container. Simply remove the top hose from its top fitting at the rear of the dryer and plumb the hose provided to the drain.
If a leak has developed in absence of using the drain hose feature, then the water is going someplace else. Unplug unit and then check behind it for the drain line being fallen down. If you need more help, please write back. User Manual can be downloaded without charge from Hotpoint website. -- SWT
Aug 04, 2010 | Dryers
How does tumble dryer work?
The heated air inside the dryer is not expelled but reused. The drum is contained inside a closed area. The heat is contained inside the dryer. No ducting to outside is needed. The moisture is removed from the heated air through a condenser before re-entering the drum. Sorta like a giant self-contained dehumidifier. As the water is removed from the clothes, it puddles up into a drain pan which periodically needs dumping. Fancier models pump out the water to standing drainpipes. This design saves energy.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 11, 2010 | AEG T58840 Dryer Electric
Whirlpool AWZ 8577 Tumble Dryer The water is not collecting in the top water container
You have a water pump in the base of the appliance this can sometimes fail or block. On the back of the dryer there should be a pipe just pull that off and blow down it, if there is a block this may well remove it. If not it's likely a pump failure.
Hope this helps
Mar 20, 2010 | Whirlpool Dryers
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Feb 12, 2010 | Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Feb 24, 2008 | Dryers
Dryers Logo
418 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
