Question about Epson Stylus CX8300 Printer
An error has occured switch off then swith on again problem persists
  • Epson Master
  • 17,130 Answers
Not a switch off/on can solve but a resetting .So remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Posted on Mar 19, 2011
Xerox Printer not starting, A fault has occurred. Fault Error 116-201
The problem description is: Fault Code 116-201: HDD Was Not Booted Due to an HDD Error Detected on Booting. Try this link first: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=387,E=0000000005750000208,K=9799,Sxi=3,Solution=obj(542)
If this does not work. Unplug the machine from the wall while still on
do not power down first. treat it like the power just went off in your building. While the machine is still off not plugged to the wall. Press the power button several times. This will erase any saved info on memory.
Plug machine back on an try again. If it does it again you will need to replace your hard drive and that will take a service call.
Dec 10, 2015 | Xerox DocuColor 3535 Copier
E301-3001 error code on cannon mf4550d
Error LCD: System Error EXXX (MF4400/MF4500/D500 Series)
Description:
A system error has occurred. <XXX> will be a three-digit code that indicates a particular type of error.
Action:
Turn OFF the main power switch, wait for more than 5 seconds, then turn it ON again. If the message persists, turn OFF the main power switch, disconnect the power cord, and contact Canon Customer Care Center.
May 17, 2014 | Canon Office Equipment & Supplies
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
HOW CAN I FIX ERROR 072-210
072-210
An error occurred when Tray 2 was used. Switch off the machine, and then
switch it on again. Contact the Xerox Welcome Center if the problem persists
Aug 22, 2012 | Xerox Office Equipment & Supplies
HP Color LaserJet 3800 dtn printer. Error message says 49.4C06 Service Error
49.XXXXX ERROR A critical firmware error has occurred.
If the message persists with different programs and print jobs, turn the printer off.
Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
Remove the printer EIO card.
Turn the printer on.
If the error does not persist, install each DIMM and EIO device one at a time.
Turn the printer off and then on again after installing each device.
Replace DIMMs and EIO devices as necessary.
If the error persists, replace the firmware DIMM.
If the error persists, replace the formatter and calibrate the printer.
Jun 16, 2011 | Office Equipment & Supplies
Hi, I have a "dead"
APP position error or Error Code 6A80
Condition: An error occurred in the APP motor.
Problems and Solutions:
  • Check for foreign material or paper debris around the purge drive system unit
    - remove foreign material.
  • Check for foreign material or paper debris around the ASF unit
  • If other solution fail, replace one off the following part
    - Purge drive system unit
    - Logic board
for more info visit: http://pcmediks.blogspot.com
Dec 28, 2010 | Canon Pixma MP450 All-In-One InkJet...
Canon MP 648 suddenly appeared a message: ERROR 5012, then after the power off and turned on again appears ERROR 5050. Printer error has occurred. TURN POWER OFF THEN BACK ON AGAIN. SEE IF THE PROBLEM...
From the service manual, both errors relate to the scanner unit:
[5012] An error occurred in the scanner FB motor.
(1) Cable connection (2) Part replacement: - Scanner unit
[5050] The AFE was faulty.
I don't know if the following YouTube video will help, but you could watch and see if it applies to your printer.
Error 5011 and 5012 Printer Canon MG 2570 MP 237 MP258
Feb 09, 2018 | Computers & Internet
I'm having an error on my kyocera ecosys FS 1118MFP. The message is "Error Occurred. Power switch turn off and on again Cf2ff". Please can you help?
this is
Controller system error
swith of and swith on the printer it will work .If this error occurs again even after the
power switch is turned off and then on
again, please replace
PWB
Jan 14, 2009 | Kyocera FS-1118MFP Laser Printer
Error 5400 - Internal temperature error
just switch it off and wait for 10 minutes then again swith it on and see
Sep 25, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Epson Stylus CX8300 Printer Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
