Question about Saeco Royal Professional Espresso Machine
Descaling the machine. please help - Saeco Royal Professional Espresso Machine
Ki ar korte parri. valo thako
Posted on Sep 15, 2011
I need help understanding how to descale delonghi expresso machine
hi Kathy.
see if this helps you out.
For machines without an automatic descaling cycle:
  1. Dissolve the descaling agent into a full reservoir.
  2. Pull the solution into your boiler by running about a cup of water out of your steam wand. ...
  3. Turn off the machine and let sit for 20 minutes. ...
  4. After 20 minutes, run about 1/2 of the reservoir out of the steam wand.
How to Descale Home Espresso Machine
or try this link.
how to descale delonghi espresso machine Google Search
Dec 12, 2017 | DeLonghi Coffee Makers & Espresso Machines
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
Water button orange light appear even after descaling
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
May 01, 2010 | Nespresso Lattissima 660.R
Is vinegar OK to descale a gaggia classic?
If you use citric acid on the Classics aluminum boiler you are risking
serious corrosion. To descale an aluminum boiler you need tartaric acid
based descaler.
  • but it is safe to use CleanCaf as a Descaler--Dissolve in water reservoir, run pump.
  • also it is safe to BAckflush the machine with Cafiza/Joe Glo/PulyCaff. NO detergent gets in the boiler. it is impossible.
  • dont use vinegar.
This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Mar 20, 2010 | Gaggia Classic Espresso Machine
Hi We have misplace user guide and our machine is
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say “Descale finished”. Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose “Yes” and push enter so the machine will tell you when you need to descale again.
Nov 25, 2009 | Saeco Royal Professional Espresso Machine
Need descaling instructions for EAM 4500 auto espresso machine
use 1/4 cup of vinegar and fill pot with cold water, run through machine
Aug 01, 2009 | Coffee Makers & Espresso Machines
The button all the way on the left is lit up in red!
the machine still work fine still descaling time with descaler not vinegar .vinegar no good descaler melt calcium follow what mark on the product to descale to reset the light i think you have to hold the steam button for 10 second thanks for using fixya pierre p.s im gonna double check how to reset the light ill get back to you
Feb 22, 2008 | Saeco Magic De Luxe Espresso Machine
Expresso machine
descaling gonna improved the pressure = stronger coffee and clean the inner boiler =warmer coffee but use descaler only not vinegar descaler melt calcium vinegar remove some calcium in littlt piece 1 part descaler 1 part water fill the water container open valve for a few second close it leave it for 15 minute and repeat untill empty after rince very good that stuff is corosif
THANKS FOR USING FIXYA
FROM MONTREAL CANADA PIERRE
Feb 18, 2008 | DeLonghi BAR 14 Espresso Machine
Saeco Royal Professional Espresso Machine Logo
32 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
