Question about Toshiba 32WLT66 32 in. LCD HDTV
MY TOSHIBA 32WLT66A WON'T TURN ON EVEN WHEN TRYING MANUALLY
  • Toshiba Master
  • 17,129 Answers
Possible failrue of the main power supply if there is no power to the set. so please check the SMPS unit with the tips given in the link below:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Mar 19, 2011
Model 20AK42 Toshiba won't turn on
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Televison & Video
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
Toshiba a505-s6960 won't turn on
You should better go to the service center of Toshiba for the best solutions. The incident may have caused major issues to your laptop.
Regards, Mrityunjay.
Jun 19, 2012 | Toshiba Satellite A505-S6960 Core 2 Duo...
Toshiba TheaterWide 57HM167 Won't Turn On After Bulb Replacement
There is a ballast which drives the lamp--a hint would be to try to be in a position if possible to see if lamp ignites at all or even for a moment.
The ballasts do fail but rarely----it develops about 12,000 plus to the lamp and is much like spark plug wires as far as rf.
Some checks would have to be made and then the ballast priced--google the model number with ballast after it to get and idea.
No cut and dried solution here--several possible causes.
Mar 16, 2012 | Televison & Video
Won''t turn on the tv also cannot change the settings manually on the tv
Thanks for stopping by.
What is the model number and manufacturer of the TV you are trying to control with the CT-90157 remote?
Not all IR codes are programmed into all remotes.
Sep 26, 2011 | Toshiba CT-90157 Remote Control
My Toshiba BDX 2500ku won't turn on...Ive used it before...now it won't even open...please help....its only about 4 months old and we've only watched about 2 movies....
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Jun 20, 2011 | Toshiba BDX2000 Blu-Ray Player
Nb 205 blank screen
Is your screen blank when you are trying to turn it on? Do the fans run and such but nothing shows up? If not then I don't know.. but if it is put you laptop in the freezer for an hour. Mine had that problem, but you won't be able to turn it off... ever again... because then it won't start up again. I would suggest to check this out as well if it is that problem. http://www.techsupportforum.com/forums/f108/toshiba-nb200-wont-boot-492391.html
Apr 02, 2011 | Toshiba NB205-N311/W Netbook
Toshiba TV will not turn on
Try to have the TV unplugged over night. If that does not solve it you may have to have the TV power supply circuit inspected for leaking capacitors, loose solders or may be a bad IC.
Aug 29, 2009 | Toshiba 32A33 32" TV
Replaced motor,now won`t spin
Something is locked in the transmission--can you turn the inner tub manually? Also, try to turn the driven pulley (the motor and belt driven). The problem could be anything from a seized bearing to a broken gear. Don't keep trying the motor while things are locked up, you could burn it out.
Aug 18, 2009 | Washing Machines
Open Questions:
See all Toshiba 32WLT66 32 in. LCD HDTV Questions
Toshiba 32WLT66 32 in. LCD HDTV Logo
373 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
