Question about D-Link AirPlus® G DI-524 Wireless Router
DI 524 router and phone LG Optimus One The phone sees the router, gets IP but internet does not work. Why? The phone works fine on other routers.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Check in the router configuration if you have a policy thats blocks the internet access for the phone
and compare the ip assigned to the phone with another device, if the two ips doesnt belong to the same network, your phone is not really connecting to the net
and you need to check the network config
Posted on Mar 19, 2011
  • Bart Btech Apr 05, 2011
    @ edeleons - you would have to be more specific on the "policy that blocks the internet access for the phone" - what policy are you speaking of?
    i have same problem, and can't google the solution anywhere. have the di-524 and 2 androids neither of which can go through the router to the internets. does it matter if it's WEP or WPA/PSK? i have set up a static ip table for mac addresses, would that matter?
    solution greatly appreciated!
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
LAn IP not configard
Yes, it is little bit complicated process, but you can do this as follows:
Step 1: Fix or assigned IP to each Computer manually or by login to the Router.
Steps 2: Then block all the ports (1 to 65534) of that IP/Computer from the Router from the Block Services Setting by login to the Router (If your Router have this setting).
This will block the Internet on that Computer but the LAN will work.
Good Luck!!!!!!!!!!!!!!!
Sep 20, 2009 | D-Link AirPlus DI-524 Wireless Router
DI-524 not working with Vista32 Dell M1330
make sure your wireless card is set to "obtain automatically an IP address"
Jan 25, 2009 | D-Link AirPlus DI-524 Wireless Router
I cannot connect to my router via the IP in the browser
Check first the cables and connections, and the broadband filter.
You need to connect through cable to configure the router.
To access the router panel you need to input the router IP address on Internet explorer bar.
default IP is http://192.168.0.1
If IP is not default, you find out IP by opening the command prompt from start menu>>all programs>>accessories>>system tools (that kind of dos mode). On command prompt type ipconfig/all.
The default gateway is router IP.
On the router access panel default settings are :
User Admin
Password leave blank
See all procedures on manual below.
Copy and paste the address below on your browser address bar.
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
Dec 08, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Connection to internet doesnt work
Your ISP has specific requirements for connecting a router to their equipment. For some the default router settings connect successfully. Some Telcos require PPPoE logins to access the network, you may either be given a static IP address or be required to accept a dynamic IP address. You need to determine from your ISP often from a help website, a chat with a technician or phone support what those requirements are. Another possibility is failure to include DNS addresses either in the router or in the network adapter's IP configuration.
Dec 13, 2007 | D-Link AirPlus DI-524 Wireless Router
Di-524 setup
Reset the DI-524 to its factory default settings and restore the other devices on your network to their default settings. You may do this by pressing the Reset button on the back of the unit. You will lose the current configuration settings. Also be sure to unplug the modem the plug it back in afterwards, a reboot of all devices on network maybe good idea also.
Jul 28, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus® G DI-524  Wireless Router Logo
198 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
