Question about LG LS-L1210CL Mini Split Air Conditioner
Hi, I replaced a comp on my Goldstar GA 1260 model split, the old capacitor had 3 contact points, the new one has got only 2? Can anyone help out?
    Problem Solver:
  • 8 Answers
Yes, your old one was probably a dual capacitor. The middle terminal was common to the compressor capacitor and fan capacitor. The new capacitor if for the compressor only. You will need to reuse the fan side of the capacitor or purchase a separate capacitor for the fan. I hope this helps.
Posted on Mar 19, 2011
Model GA-1215LC
I want to replace this air conditioningunit GoldStar GA-1215C for a heat/air conditioning unit. Any recommendations?
Jul 09, 2012 | Goldstar Heating & Cooling
I have C7 error on an LG 9000 heating and cooling unit new installation. I dont have a manual to help with the code. Please Help
C7-Split compressor over current. Check condenser. If full of dust, clean it. Check rpm of fan motor. If less rpm replace capacitor.
Oct 01, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I HAVE A 5MFD OVAL CAPACITOR WITH 2 PINS CONNECTOR AND MY OLD ONE HAS 3 YELLOW GOES TO ONE OF THE PINS RED AND PURPLE GOES TO ANOTHER PIN AND THE BROWN GOES TO ANOTHER PIN THIS IS FOR THE OLD CAPACITOR BUT...
You need to replace it with a matching 3 pole capacitor. Look at the rating on your old capacitor, on a 3 pole it should read (ie): 5/35 mfd. This is a split type capacitor and usually controls 2 motors. There are a wide varety of capacitors. Also, one of the terminals will be a common terminal, so be sure to put it back together correctly.
Jul 09, 2010 | Goodman CKL24AR24 Air Conditioner
Amcoraire AOS091HX Dead
had the samething. 2 blown capacitors on that middle board. got new capacitors and system was back online. check out digikey electronics and order your new capacitors. hope nothing else is wrong with the board.
Jan 02, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Wires
2 brown wires go to a split capacitor if you have a dual cap which has three terminals marked comp fan com if u have this type of capacitor then the brown wire goes to fan and the brown and white gets capped with a wire nut. whenever replacing a fan motor you should also replace the cap or at least check the capacitance to see if it is still good. you have to check it with a meter that test microfarad.you can get a permanent split capacitor and mount it in there then u use the brown on one side and the brown and white on the other side it only has 2 terminals.
May 31, 2009 | GE Heating & Cooling
Replacing old 3 wire condensor fan motor with new 4 wire
the new one needs its own capacitor 5 to 7.5 uf hook to the 2 brown wires
May 08, 2009 | Goodman CLQ36AR49 Air Conditioner
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Filters needed for Old GE Zoneline 2100
My name is brian pfeiffer . I run a ptac business in griffin ga. I have many parts and filters for most all types of ptac units. Please feel free to contact me at brian@dreamgreenservices.com. Nobody can beat my prices!!!! Or call me at 770-233-9987
Sep 03, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Mvh1615
It doesnt matter how old a system was. components can be failed at any point in time. unplug the unit. carefully disassembly and visually check the diode near magnetron and capacitor, it might be broken.If seems good, check the thermostat continuity,if beeping. changage your magnetron. be careful capacitor store charges that deadly. discharge the capacitor first.
when you change mag. change the diode too.
Jul 24, 2008 | Goldstar MV-1501 Microwave Oven
LG LS-L1210CL Mini Split Air Conditioner Logo
195 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
