Question about Samsung Office Equipment & Supplies
Toner exhaushted - Samsung Office Equipment & Supplies
  • Samsung Master
  • 32,281 Answers
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Posted on Mar 19, 2011
Toner dumping straight into toner bag
use original toner OR reset toner indication
Sep 12, 2012 | Toshiba 2860 Copier
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
My 2004 4runner 81,146 miles, front brakes replaced 11/2610, 4 wheels spin balanced ands tires rotated. Month later check engine ligh, VSC and VSC OFF lights come on. Toyota dealer says a zero point...
if it is just the cat. the replace just the cat i bought one used for 35 bucks at the auto wreakers a good cat .you should be able to see through it it has like a honey comb inside it and newer cars and trucks won't run right without it now i have my own welder if you cut it off use a recipercating saw you can buy exhaust pipe extensions at any parts dealer and you can clamp it on and new cat is very exp..
Jan 01, 2011 | 2004 Toyota 4Runner
Waste toner gets full before toner runs out
Actually, the waste toner should get full sometime before the regular toner runs out in laser printers that have several toner cartridges compared to the single waste toner reservoir.
You can dump the toner reservoir out and avoid buying the empty waste toner 'reservoir.'
I did this on my Brother Laser printer and saved about $30 or so for an empty plastic waste toner bottle or jar.
If this is the way the Kyocera-4020DN is, then I would put the waste toner, which is just that, waste, and put it into a plastic zip loc storage bag and throw it away. Don't breath the toner.
Good luck on this repair.
Jul 19, 2010 | Office Equipment & Supplies
Toner fixing massage
If you mean " toner mixing ", you should check the toner ( if the toner is hardened, replace toner) and toner unit, remove toner unit shake it ( verry well ). If you havve skills and good will, carefully dismantle the toner unit and vacume it, then put it back, put fresh toner and then after auto initialization when message "toner mixing" stops you can use it again.
If the copier was without toner for a long time yust let her do the toner mixing, eventually turn it off and on for better toner dosing.
Pls. rate
May 03, 2010 | Canon imageRUNNER 2000 Copier
Inatallation of a printer
Hello , I believe I can help you out.
First here is a bit about your machines toner maintenance.
Second will be how to change the cartridge.
Remember if I was of assistance please be kind and leave a kind quick testimonial and good rating.
Maintaining the toner cartridge
Toner cartridge storage
Toner cartridges contain components that are sensitive to
light, temperature, and humidity. Samsung suggests users
follow the recommendations to ensure the optimum
performance, highest quality, and longest life from your
new Samsung toner cartridge.
Store this cartridge in the same environment as the printer
it will be used in; this should be in controlled office
temperature and humidity conditions. The toner cartridge
should remain in its original, unopened package until
installation – If original packaging is not available, cover
the top opening of the cartridge with paper and store in a
dark cabinet.
Opening the cartridge package prior to use dramatically
shortens its useful shelf and operating life. Do not store on
the floor. If the toner cartridge is removed from the printer,
always store the cartridge:
• Inside the protective bag from the original package
• Correct side up in a horizontal position (not standing on
end)
• Do not store consumables in;
- Temperature greater than 40°C (104°F).
- Humidity range less than 20% and not greater than
80%.
- An environment with extreme changes in humidity or
temperature.
- Direct sunlight or room light.
- Dusty places.
- A car for a long period of time.
- An environment where corrosive gases are present.
• An environment with salty air.
Handling instructions
• Do not touch the surface of the photosensitive drum in
the cartridge.
• Do not expose the cartridge to unnecessary vibrations
or shock.
• Never manually rotate the drum, especially in the
reverse direction; this can cause internal damage and
toner spillage.
Use of non-Samsung and refilled toner
cartridge
Samsung Electronics does not recommend or approve the
use of non-Samsung brand toner cartridges in your printer
including generic, store brand, refilled, or remanufactured
toner cartridges.
CAUTION: Samsung’s printer warranty does not cover damage to
the machine caused by the use of a refilled, remanufactured, or
non-Samsung brand toner cartridge.
Estimated cartridge life
Estimated cartridge life (the life of the toner cartridge yield)
depends on the amount of toner that print jobs require. The
actual print-out number may vary depending on the print
density of the pages you print on, operating environment,
printing interval, media type, and/or media size. For
example, if you print a lot of graphics, the consumption of
the toner is high and you may need to change the cartridge
more often.
Redistributing the toner cartridge
When the toner cartridge is near the end of its life:
• White streaks or light printing occurs.
• The warning message, Toner Low displays on the control
panel.
• The Smart Panel program window appears on the computer
telling you that the toner cartridge is low on toner.
• The Status LED blinks red.
If this happens, you can temporarily reestablish print quality by
redistributing the remaining toner in the toner cartridge. In
some cases, white streaks or light printing will still occur even
after you have redistributed the toner.
1 Open the front cover.
2 Pull the toner cartridge out.
3 Thoroughly roll the toner cartridge 5 or 6 times to
distribute the toner evenly inside the toner cartridge.
NOTE: If toner gets on your clothing, wipe it off with a dry
cloth and wash clothing in cold water. Hot water sets toner into
fabric
Changing cartridge:
_______________________________________________________
CAUTION: Do not touch the green underside of the toner
cartridge. Use the handle on the toner cartridge to avoid
touching this area.
4 Hold the toner cartridge by the handle and slowly insert
the toner cartridge into the opening in the machine.
5 Tabs on the sides of the toner cartridge and corresponding
grooves within the machine will guide the toner cartridge
into the correct position until it locks into place completely.
6 Close the front cover. Make sure that the cover is securely
closed.
Replacing the toner cartridge
When the toner cartridge is completely empty:
• The printer stops printing.
telling you that the toner cartridge is empty.
• The Status LED lights red.
At this stage, the toner cartridge needs to be replaced. For
order information for toner cartridges, see page 7.1.
1 Pull the toner cartridge out.
2 Remove the new toner cartridge from its bag.
3 Roll the toner cartridge 5 or 6 items to distribute the toner
Thoroughly rolling the toner cartridge will assure
maximum copies per toner cartridge.
4 Remove the paper protecting the toner cartridge.
fabric.
touching this area.
5 Hold the toner cartridge by the handle and slowly insert
6 Tabs on the sides of the toner cartridge and corresponding
7 Close the front cover. Make sure that the cover is securely
closed.
Good Luck!
Mar 30, 2010 | Samsung SCX-4300 Monochrome Laser...
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine. to supply the toner always do this, 1-insert the new toner bottle in the toner section and close the cover. 2-Press "Utility/Counter" Button. 3-click on "USER CHOICE" or "USER SETTING" 4-click on "Toner Supply" 5-Toner bottle will start moving and hence the error message will not appear again.
Oct 27, 2009 | Minolta bizhub 200 All-In-One Printer
Toner exhaust yellow toner
samsung clp color leserjet printer writes this massage toner exhaust yellow toner. i have done the toner refil without the reset chips about two times now and i have been printing for some time now i get the message "toner exhaust yellow toner"
Oct 01, 2009 | Samsung CLP 315 Laser Printer
How do I install the toner cartridge?
I reproduce below the content from Ricoh official website. The instructions to install toner cartridge are as follows:
Note: You can make about 50 copies even after the char_ric09.gif Add Toner indicator begins flashing, but replace toner early to prevent poor copy quality.
Please read the following warnings and notes before attempting to add toner.
WARNING
  • Do not incinerate used toner or toner containers. Tonerdust might ignite when exposed to an open flame. Dispose of used tonercontainers in accordance with local regulations.
  • Keep toner (used or unused) and toner containers out of reach of children.
  • Iftoner or used toner is inhaled, gargle with plenty of water and moveinto a fresh air environment. Consult a doctor if necessary.
  • If toner or used toner gets into your eyes, flush immediately with large amounts of water. Consult a doctor if necessary.
  • If toner or used toner is swallowed, dilute by drinking a large amount of water. Consult a doctor if necessary.
  • Avoidgetting toner on your clothes or skin when removing a paper jam orreplacing toner. If your skin comes into contact with toner, wash theaffected area thoroughly with soap and water.
  • Iftoner gets on your clothing, wash with cold water. Hot water will setthe toner into the fabric and may make removing the stain impossible.
To replace the toner, follow these steps:
  1. Keep the device switched on and only add toner when "Toner is Almost Empty" is displayed
  2. Open the Front Cover
  3. Lift the large green handle up to its full extent
  4. Press and hold down the green lever to the left of the green handle
  5. Use the green handle to pull out the Toner Tray slightly then release the green lever
  6. Pull out the Toner Tray to its full extent
  7. Push the neck of the Toner Bottle back towards the device until you can see the top of the bottle
  8. Lift out the Toner Bottle by the neck - being careful not to scatter loose toner
  9. Dispose of the Toner Bottle in accordance with your local environmental instructions
  10. Obtain a new Toner Bottle and shake it gently from side to side at least 5 times
  11. Remove and discard the black cap and place the Toner Bottle in the tray with the neck towards you
  12. Push the neck back into the black housing of the tray
  13. Push the whole assembly back into the device until it clicks into place
  14. Push the green handle down fully and close the Front Cover
  15. The device will perform a few seconds of internal checks before it is ready for use again
Important:
  • Fault may occur if you use toner other than the recommended type.
  • When adding toner, do not turn off the operation switch. If you do, settings will be lost.
  • Always add toner when the device instructs you.
  • When a message "Add toner." is shown on the display panel, replace the toner.
  • Store the toner bottles in a cool, dry place free from direct sunlight.
  • Store on a flat surface.
  • Do not repeatedly install and remove toner bottles. This will result in toner leakage.
  • Do not shake the removed toner bottle. Remaining toner might scatter.
Aug 17, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
