My home phone was working fine in the day time but now all the time when someone rings me it only rings once and so i need to know what the problem is and how to get the phone system working normally.
    Brigadier General:
  • 8,546 Answers
Perhaps you could contact your telephone service provider and ask them. I would think i's a Central Office issue or a user-selectable function.
Posted on Mar 19, 2011
Incoming calls on home phone ring 1 time and then extreme static
When you unplug everything connected to the phone jack what happens? If it works, you have too many ringers or a short on the line. If it still trips the ring, you have a defective box.
Carl
Jul 06, 2009 | AT&T Lands Phones
I have a Guardian home security system and comcast digital voice. After switching to digital voice, sometimes if i call my house, I hear sounds like a fax machine, sometimes it sounds like someone has...
Your system has been programed by your alarm company for remote programing by their techical department. They can access your system to change codes, reset your system's time/date and do remote diagnostics. Most security system manufacturers allow this remote access by having the security system answer the telephone after so many rings, the security system then picks up and waits for a frequency tone from the security dealer's computer. Once this occurs the dealer can access your system. Your dealer may have to change the program settings if this is causing interference. A second possibility is do you have remote access to your system? Some systems have the ability for the home owner to remotely access their system from any outside telephone. This allows the customer to arm/disarm their system while away from home. This could be causing your problem.
Jun 13, 2009 | Uniden 2.4 GHz Expandable Phone System...
Incoming call rings one time and disconnects
Unplug all phones but one in jack 11 at the cabinet and have someone call in. If it doesn't work, you probably have a bad cabinet. If not, I'm guessing one of your extensions is faulty.
Carl
Apr 06, 2009 | Panasonic KX-TA308 Phone
Alarm does not go off when the off button is hit
Hello!!
try hard resetting once according to ur manual!!! and do let me know.. thanks you!!!
Jan 12, 2009 | Samsung Blackjack SGH-I607 Smartphone
New ge dect 6.0 phone receives calls but won't ring out loud
I had the same problem and it persisted for a few days. Once i sat down and found the manual at ge's home electronics website, the problem was resolved. This is a little embarasing because it's quite an easy fix. my phone handset was displaying a musical note with a line through it. This is to show that the "Do Not Disturb" function is enabled. There is an illuminated button on the base that says do not disturbe.... i hit the button and the ringer works again. If you had the same problem, you are not alone my friend. Time to double our ginko intake for the day. *laugh*
Nov 18, 2008 | Lands Phones
Can't call out or answer phone
phone rigs once and i'm unable to answer the phone. Caller ID does not show the numbers all the time.
Sep 27, 2008 | Panasonic KX-TG1033S Cordless Phone
Number of rings on Panasonic phone
Hi Dana, I finally bought a new phone!  I came home & plugged it in & it had the same problem.  I called my cable provider (I have digital voice through them) and they were sending someone out when I discovered that I had moved my cable box a while back & realized that I had the front (where all the lights are) aiming into a wall.  I moved the box & then my phone worked.  I was also have a lot of problems with static & garbled sounding voice on my old phone which has been solved by the new & improved cordless phone.  Good luck!!! Maggie
May 21, 2008 | Panasonic KX-TGA560M 5.8 GHz Cordless...
My motorola pebl wont ring but I can play the ringtones manually. Help
Well look on your settings and set your ringing volume to full . check your phone for any settings that may affect your fone ringing . e.g make sure it isnt on silent , Hope i helped
Oct 16, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Phone calls going to voice message without ringing while person is there.
Question: What does this have to do with a Panasonic KX-T7425 phone? Is a Panasonic phone hooked up to your Partner system?
Sounds like the system believes the phone is in use. Is the partner phone in question an MLS model? MLS-6, MLS-12 etc.. They all have keypad problems and buttons could be activating on their own randomly, making the phone in-use on the system. The message waiting light may not come on until the phone is no longer in-use. Usually phones with this problem will at least beep randomly when it thinks the buttons are being pushed.
Oct 11, 2007 | Panasonic KX-T7425 Corded Phone
Panasonic KXTA624
Barry Decker,
I have the same system in my home and having problems with my phones as well... Didderent problems but problems... Do you know where you would call to get it serviced??
Thank you,
Brad Wilson
Mar 15, 2007 | Panasonic KX-TA62470-2 (KXTA624702)...
 Grubhead
Grubhead
