Daigram to fit a fan belt to a au ford falcon 6cyl 1999
    Brigadier General:
  • 6,277 Answers
You might find it a bit difficult receiving an answer, other than this one! You have posted onto the washing machine forum ;-0)
Having said that have you tried for a manual to help you? If not-
You will need to type into your search engine/web browser 'ford falcon manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model date, I would think!
Good luck anyway and don't forget to vote!!!
John C
Posted on Mar 19, 2011
Sorry it's a au falcon 5litre
What is wrong with an AU Falcon is it the V8?
I have a 6cyl AU with just under 200,000km and it has not giver any problems
Apr 09, 2017 | Cars & Trucks
Iut just bought a ford au 1999 with a remote but tonight I cannot open the car door..
if genuine au remote.. check the fob battery
could be a faulty door lock actuator or module fault
you will find the free AU falcon repair manual handy
Ford Falcon AU 1998 2002 Workshop Manuals Factory Service Manuals
Nov 24, 2016 | Ford Cars & Trucks
2002 AU ford falcon alternator change over.?
Disconnect battery take note of the way the drive belt is fitted write it down using cogs as markers then draw the belt onto them in same order (belt only fit one way) then with a 3/8 ratchet leave r the adjuster and remove belt unplug wiring undo bolts holding it to the motor.
Sep 25, 2016 | Ford Falcon Cars & Trucks
Red fanbelt light on dashboard on AU Ford Falcon. If it comes on what does it mean??
have a look under the hood as it probably means that the belt is broken, needs replacing or needs adjustment.
Dec 14, 2014 | 1999 Ford Falcon
How to adjust parking brake on au ford falcon 1999?
ford park brakes are adjusted by a nut in the brake calliper and then self adjust. Get a ford workshop manual and see how it is done as it is a bit complicated
Jul 28, 2014 | 1999 Ford Falcon
Replace a fan belt on 1999 AU Falcon
replacing fan belts is easy except for some model have a vry little room to work on... to replace belt, 1st look for the tension pulley, its an indipendent pulley that its only purpose it to stretch the belt. at the back of that pulley you'll see a bolt loosen it then lose also the tension bolt located near at that area too... once youve done that it would be easy for you to remove and replace the belt... hope that helps..
Mar 31, 2011 | Ford Fairmont Cars & Trucks
How do you replace a driving belt on a 1999 AU ford falcon
start by unplugin the electric fans then remove the two 10mm bolts holding them in, the bottom of the fans are held in by a slot that they sit in so after you remove 2 bolts just lift the fans out. then you will see a tensioner i think it has 3/8 drive square hole in it( could be 1/2'' drive) just pull it down with a long bar with a 3/8 end on it to release the tension, while doing that slide the belt of,. if your car doesnt have a picture diaghram on the under side of the bonnet for drive belt routing draw a picture incorprating all the pulleys an how the belt goes around them. once the belt is of put the new one on exept over the power steering pump pulley, then pull on the tensioner again to release tension and slide the belt over the p/s pulley. these instruction are for the 4.0l falcon motor, the 5.0 v8 is really similar
Aug 21, 2008 | 1999 Ford Super Duty F 550
Fitting rear seat covers to AU Ford Falcon
To remove the rear seat off an au falcon get in the rear of the car facing the opposite way to which you drive facing the rear seat. you need to slide your hands along down where the seat belt conectors are pulling it up abit. than you need to use quite a bit off force pulling it towards your self.
May 04, 2008 | Baby Gear
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
