Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2003 Harley sportster anniversary
Set trip meter and then speedometer stopped work ant turn signals any ideals what this could be and how to fix it?
  • 1 more comment
  • tamissa Aug 02, 2008
    2003 Harley sportster anniversary add.
  • 03flstsi Aug 26, 2008
    I have an 03 springer heratige. Last time I rode no issues(last week). Yesterday I went for a ride and my speedo and odometer quite. The lights come on and the speedo flickers when I turn on the ignition but it doesn't register when I go and the odometer shows milage but doesn't increment.
    Any ideas?
  • Anonymous Nov 13, 2008
    Speedo not working
I had the same problem with my 2000 Electra Glide Ultra Classic. Changing sensors didn't help and I eventually took it to the dealership where they found a crimped wire from the speedo in the wiring harness that runs from the intstrument panel down and under the frame. It cost $150.00 to find that out. The mechanic told me it is a fairly common problem caused by turning the front wheel to its maximum left and right too much. The wires are not long enough and eventually either pull apart inside the insulation (thats what mine did) or pull loose from their connection. Where I store my bike requires me to "wiggle" it in and out of its space and that requires lots of turning and backing which caused it. Now that has been a year ago and I now have the problem of riding down the highway and everything shutting down for no apparent reason and with no warning. Could be a major problem in traffic some day. The lean sensor sounds like something to check into. Too much electronics now for the average rider to decipher and too easy for something to cause a problem. Good luck!
Posted on Nov 19, 2008
Had same problem with my -03 Deuce. There's a magnetic speed senson on top of transmission, secured by one allen bolt. First, check the sensor for metal shavings, the magnet is pretty strong and shavings can interfere the speedo. In my case there was no shavings, so I bought a new sensor, that fixed the problem.
Posted on Sep 10, 2008
    Genius:
  • 2,028 Answers
This model has an electronic speedo, so check the wires and connections for the speedo. Also check for any inline fuses or relays that may have blown.
Posted on Aug 06, 2008
1200 sportster C. after 18 klm. riding the speedometer cuts out signals wont self cancel bike runs good
Rob, some say its a speed sensor issue, clean or replace. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sportster Speedometer Problem Harley Davidson Forums
Speedometer auto cancel directionals stopped working Twin Forum Harley...
Speedo auto shut off for turn signal not working and wont idle
Jul 28, 2016 | 2005 Harley Davidson XL 1200 C Sportster...
No horn no turn signals no speedometer.
Hi Anonymous, please be aware that this question has already been asked and answered. Thank you
Jun 22, 2013 | 2003 Harley Davidson XL 1200 C Sportster...
Speedo stop working 2005 sportster 883
Hi Anonymous, before you run out and by a new speedometer check every connection in the speedometer circuit, look for corroded, broken or loose pins using a dab of dieltric grease repair as necessary. For a free wiring diagram please visit website below:
Harley Davidson Wiring Diagrams and Schematics Good luck
May 20, 2012 | 2005 Harley Davidson XL 883C Sportster...
Shock adjustment on sportster 50th anniversary model
The shocks are adjustable for preload. You need a special tool to set them with. The bottom spring seat turns.
Aug 08, 2010 | 2003 Harley Davidson XL 1200 C Sportster...
Electronic speedometer and trip meter stoped
Could be a number of things causing this problem .seek advice from your local harley agent ,it may be a common fault .and they may have some answers
Mar 14, 2010 | 2003 Harley Davidson FLHRCI Road King...
Speedometer on my 2006 Harley XL stopped working.
Pull the speedometer sensor from the top of the tranny and clean it off.
Jul 05, 2009 | 2006 Harley Davidson XL 1200 L Sporster...
Lands Phones Logo
241 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
