yes I got the same problem, I Fix myself.(model T80BC)
unplug main power cable, remove top cover (remove 4 screw from the bottom and knob from the side)disconnect control panel cable from main board.look at the attached picture.in the photo close to power cable connector will see a slot
(look at the black arrow mark pointed ).insert plastic switch to this slot, make sure both side properly mounted.then move toaster push down lever up and down. it should move as usual without any obstruction. now put back control panel cable and top cover,knob,and all the screws. plug cable into the power,it should work.
see switch
