Question about Microwave Ovens
I've got a broken Breville Ikon 550 blender. It smokes with in seconds of turning on, looks like the blade assy is broken as its little bit wobbly & gives resistance when turning. How & where can I get it fixed?
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 19, 2011
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
Broken door catch
First turn the micro door upside down and shake it this may dis lodge it make sure its unplugged and rotating table is removed.If you can see the piece try tweezers or needle nose pliers but again make sure it is unplugged during any handling period!
Second UN plug the device remove its cover with phillips driver or what is needed after it is removed go to the safety switch where the piece is located remove it and shake the piece it may come out if not just replace the complete safety switch
Apr 06, 2012 | Zanussi ZM24ST Microwave Oven
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
I have bought a second hand breville fan assisted breadmaster, but it has no manual - can you help please?
Assuming its a BR1 try this: http://safemanuals.com/user-guide-instructions-owner-manual/BREVILLE/BREVILLE%20PART%201-3-_E
hope this helps!
Jul 24, 2011 | Microwave Ovens
I need instructions for an Anthony Worral Thompson blender made by BREVILLE
I hope this helps.
Mar 21, 2011 | Microwave Ovens
I purchased a G E single serve blender...used it once, now the blade base will not fit into the blender base...what would cause this to happen?
The problem may be that the base is not turned all the way into the cup due to damage of the threads or the wrong gasket or having more then one gasket. This would keep the tabs from aligning with the notches in the base. Try the other base and cup and if that doesn't work then the notches may be the problem. There may be some foreign object jammed in them
or they may damaged. Take a small screwdriver and see that the spring loaded ramps in the notches compress. GE's cusomer assistance number is 1-877-207-0923. These units have a 2 year warranty though I dont know about second owners.
Nov 21, 2010 | GE Microwave Ovens
My blender won't power on, the lights don't turn on. I've had the blender for 1 year and have never had any problems with it. In the past month it would only work intermittently, and now it doesn't work...
sometimes something (food etc) gets "stuck" in the lock mechanism, preventing it from turning. unplug the blender and give the locking mechanism a cleaning with a bottle brush or rinsing it under very hot water. also the lock could be broken/chipped, also preventing it from turning.
i must admit that I broke my locking mechanism 5 years ago by not "seating" it correctly and forcing it. my hubby somehow removed! the locking mechanism but now it goes on - turns - as soon as I plug my blender in (because the stop/lock doesn't exist anymore). so I must be very careful to always have the lid on before I plug it in. but it's a braun blender and I love it. so i've kept it all this time.
Oct 06, 2010 | Microwave Ovens
I need to change the blade in my Braun blender, model 4 184. And I cannot loosen the old blade. I see no way to unscrew it. Please help
Just a suggestion: look underneath - there may be 2 prongs that you have to press together to push out, rather than having to unscrew it.
Sep 12, 2010 | Microwave Ovens
Where can I get a copy of a Breville Express Cooker (EXC15) manual? I had a cooker given to me but alas no "how to use" instructions.
Hi I have the same model - I absolutely love it. The only problem is that the seal is broken and because Breville no longer supply parts I'm using it more as a slow cooker!
It's pretty simple to use:
The basics:
1. Pull the handles apart (note you must have the 'pressure lock - the only sliding knob on the lid) in the 'unlocked position'.
2. Set the temperature on Max (only until the meat, onions etc are brown, then turn down to 1 or 2- just enough to keep the orange button 'popped' on the top of the machine
3. turn the timer (bottom dial on the front of the cooker) to an hour (you can always turn the dial more if needed, but not reduce time) by the time you've browned meat & chopped veges, etc that will be about 10-15 gone. I've never had it pressure 'cooking for more than an hour for anything'
3. re timing - casserole takes about 40 min from when the orange button on top 'pops' up (ie. steam build up enough pressure to cook quickly)
4. don't over fill - there's a little cast iron bump about an inch from the 'top' inside the cooker - that's about the max.
5. if you're cooking meat dishes have the dial on the top 'pressure release dial' on 3 - lighter dishes (e.g. soups) have on 1 or two.
6. until you get use to it keep an eye on the orange button - you get to know what temp to put it on by how much steam is released - it it's hissing away, turn the temperature down.
7. makes great casseroles, rissotto, soups (even with dried beans, only about 40 min)
if you ever find a supplier for seals, post an answer!
May 19, 2010 | Microwave Ovens
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
