After installing Windows 7 I got an overclocking error message. Updated the BIOS via online instructions. Now when I turn the power on the computer fires up on the first screen than dies and restarts 8 - 12 times before finally booting successfully. I don't think it is a power supply problem (no problems before the software change and tweaks).
  • 961 Answers
Http://windows.microsoft.com/en-US/windows/downloads/upgrade-advisor
You might try running this. Did you uninstall any software before install of Win 7? You may have to uninstall and then install latest drivers.
Posted on Mar 19, 2011
Toshiba c55t-a5222 bios update, after reboot no screen
Did it at anytime lose power during updating? If so, motherboard was damaged and needs replaced. Otherwise, try to boot into'Safe Mode with Networking' and if it turns on, immediately re-install your graphics (video) driver. See this link for instructions on booting in to safe mode on a Toshiba: http://forums.toshiba.com/t5/Windows-7-Knowledge-Base/How-To-Start-your-Windows-7-computer-in-Safe-Mode/ta-p/272525
Feb 01, 2014 | Computers & Internet
Tip
How to tweak your computer
Step 1
Back up important files. This includes impotant datas stored on your computer
Step 2
Update the firmware of your computers BIOS. Also update or patch your OS to the lates update and even your hardware devices must be updated as well.
Step 3
Also before proceeding ,remember to get a BENCHMARK test program that will help you see the changes and also monitor the temp. of your processor after overclocking
Make sure that your BIOS is also set to shutdown once illegal voltage or temp. will be detected
Step 4
Ensure that the CPU FAN is clean and is still calibrated to the right rpm
Step 5
Power on your unit ,hit the hotkey to access setup.On the BIOS go to ADV. CHIPSET option.Then look for"clocks, "frequency/voltage control" or "voltage options." This will look unique on each brand of computer.You can overclock by modifying "CPU bus frequency" or "CPU FSB frequency." Increase this value slightly. In some cases, you will be able to increase your "CPU multiplier" through the BIOS.If your BIOS has none of these options,your motherboard is not capable of overclocking the processor.
Step 6
You can also try overclocking your MEMORY AND VIDEO speed. Some motherboards have this options on the BIOS as well
Step 7
You can consult your motherboards manual to know the operating voltage of your cpu or type in the model of the board on yahoo or google.
on Dec 19, 2009 | Computers & Internet
With VIA K8M800, geforce 6200 graphics card causes windows to crash
This appears to be a driver issue. Or perhaps that card is simply not compatible with the win 7 OS.
Sep 06, 2017 | Computers & Internet
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    Oct 09, 2011 | HP Mini 1000 Netbook
    I have a Motherboard MSI 865PE Neo3 MS-6728 ver3.0. You can install Win XP normally but is will never boot any Windows 7 CD installer with boot error "CDBOOT: Cannot boot from CD - Code:5". I...
    be sure if you computer and the installer is the same as 32 or 64 bit.. check your computer and your installer.... be sure you have updated version of your motherboard..
    Jun 30, 2011 | MSI 865PE Neo3-FS Motherboard
    Installed Windows 7 - got an "overclocking error"
    please clear the cmos by moving jumper pin next to the battery area on the motherboard, make power pulg is off before moving jumper to clear bios memory to default
    Mar 07, 2011 | ASUS Computers & Internet
    I have a HP Z400 with windows xp sp3 installed. Recently the computer has been randomly turning itself off twice a day with no error messages. The computer can be turned back on right away and nothing...
    I would update the drivers, check with the chip set manufacturer for updated firmware and run diagnostics on the RAM and hard drive.
    That should cover most angles.
    Feb 10, 2011 | HP Z400 Win 7 W3503 2502GB (FL940UTABA) PC...
    Overclocking past 2.7GHz with Q6600 GO step
    Please check BIOS update from mainboard manufacturer website it there has a solution for overclocking and others. Else don't push your motherboard so hard, you might get extraneous problem.
    May 28, 2008 | Foxconn N68S7AA-8EKRS2H nForce 680i SLI...
    Problem restrart pc /NO AUTORESTART
    It sounds like you're trying to overclock your CPU, and you have exceeded what the CPU is capable of, under the current conditions. When you start the computer, enter BIOS setup (e.g. press the DEL key), and adjust the CPU settings to default. If you're not sure how to do this, choose the "LOAD OPTIMAL SETTINGS" or "LOAD DEFAULT SETTINGS" option from the main BIOS menu. If you are not getting this error until after Windows has started, then there is software installed that is trying to overclock the CPU for you. Uninstall it. It may be a program provided by Asus, or may be a third-party program. It will probably have "tweak" or "overclock" in the name. Overclocking can achieve an increase in performance, but will void the warranty, and does reduce the lifespan of the parts, and tends to make Windows crash more often. It can cause immediate failure of the parts. It should only be done if you understand and accept the risks, and have decided the reward is worthwhile. For most users, it is not worth it.
    Oct 01, 2007 | ASUS P5LD2-VM Motherboard
    Computers & Internet Logo
    60 people viewed this question
    Alun Cox
    David Payne
    David Payne
