I have a failed drive on my server 2003 standard edition, may someone can help me on how to replace the bad hard drive to a new one and rebuild again my raid, i am using software raid 1. thanks stanley
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Depends if the raid configuration is made by hardware or software
if its made by hardware you can find how to define the raid in the bios or using the server's start disc to start the windows 2003 installation
regards
Posted on Mar 19, 2011
I have a Gen 8 Hp server with 5No 600GB HDD. The first two disk are mirrored, the other 5 are on raid 5. 1 of the 3 on raid 5 is flagging amber colour. How do I replace the HDD without losing Data?
Before replacing drives • Be sure that the array has a current, valid backup. • Confirm that the replacement drive is of the same type as the degraded drive (either SAS or SATA and either hard drive or solid state drive). • Use replacement drives that have a capacity equal to or larger than the capacity of the smallest drive in the array. The controller immediately fails drives that have insufficient capacity. In systems that use external data storage, be sure that the server is the first unit to be powered down and the last unit to be powered up. Taking this precaution ensures that the system does not, erroneously, mark the drives as failed when the server is powered up. Replacing drives The most common reason for replacing a drive is that it has failed. However, another reason is to gradually increase the storage capacity of the entire system. NOTE: In fault-tolerant configuration, hot-plug hard drives can be replaced when server is ON, but in case of a Non-hot-plug hard drive, it should be replaced when server is OFF. For systems that support hot-pluggable drives, if user replace a failed drive that belongs to a fault-tolerant configuration while the system power is on, all drive activity in the array pauses for 1 or 2 seconds while the new drive is initializing. When the drive is ready, data recovery to the replacement drive begins automatically. For systems that support non-hot-pluggable drives, if user replace a drive belonging to a fault-tolerant configuration while the system power is off, a POST message appears when the system is next powered up. This message prompts user to press the F1 key to start automatic data recovery. If user do not enable automatic data recovery, the logical volume remains in a ready-to-recover condition and the same POST message appears whenever the system is restarted. Automatic data recovery (rebuild) When user replace a drive in an array, the controller uses the fault-tolerance information on the remaining drives in the array to reconstruct the missing data (the data that was originally on the replaced drive) and then write the data to the replacement drive. This process is called automatic data recovery or rebuild. If fault tolerance is compromised, the controller cannot reconstruct the data, and the data is likely lost permanently. Time required for a rebuild The time required for a rebuild varies, depending on several factors: • The priority that the rebuild is given over normal I/O operations (user can change the priority setting by using HP SSA/ACU) • The amount of I/O activity during the rebuild operation • The average bandwidth capability (MBps) of the drives • The availability of drive cache • The brand, model, and age of the drives • The amount of unused capacity on the drives • For RAID 5 and RAID 6, the number of drives in the array • The strip size of the logical volume • Firmware versions of the Smart Array Controller and Hard Disk Drive • Presence of BBWC/FBWC CAUTION: Because data rebuild time may go upto the rate of 200GB/15 minutes, the system could be unprotected against drive failure for an extended period during data recovery or a drive capacity upgrade. When possible, perform rebuild operations only during periods of minimal system activity. When automatic data recovery has finished, the drive status LED changes from flashing green to solid green. If the drive status LED on the replacement drive changes to flashing or solid amber, the rebuild process has terminated abnormally. If an abnormal termination of a rebuild occurs, identify the cause and appropriate corrective steps. Abnormal termination of a rebuild If the activity LED on the replacement drive permanently ceases to be illuminated even while other drives in the array are active, the rebuild process has terminated abnormally. The following table indicates the three possible causes of abnormal termination of a rebuild. Cause 1: An uncorrectable read error has occurred. 1. Back up as much data as possible from the logical drive. CAUTION: Do not remove the drive that has the media error. Doing so causes the logical drive to fail. 2. Restore data from backup. Writing data to the location of the unreadable sector often eliminates the error. 3. Remove and reinsert the replacement drive. This action restarts the rebuild process. If the rebuild process still terminates abnormally: 1. Delete and recreate the logical drive. 2. Restore data from backup. Cause 2: The replacement drive has failed. Verify that the replacement drive is of the correct capacity and is a supported model. If these factors are not the cause of the problem, use a different drive as the replacement. Cause 3: Another drive in the array has failed. A drive that has recently failed can sometimes be made temporarily operational again by cycling the server power. 1. Power down the server. 2. Remove the replacement physical drive (the one undergoing a rebuild), and reinstall the drive that it is replacing. 3. Power up the server. If the newly failed drive seems to be operational again: 1. Back up any unsaved data. 2. Remove the drive that was originally to be replaced, and reinsert the replacement physical drive. The rebuild process automatically restarts. 3. When the rebuild process has finished, replace the newly failed drive. However, if the newly failed drive has not recovered: 1. Remove the drive that was originally to be replaced, and reinsert the replacement physical drive. 2. Replace the newly failed drive. 3. Restore data from backup. More Resources: • Click here for ProLiant Self Solve. • Click here for Creating and Managing Hard Drive Online Spare Technology. • Click here for 17xx Power-On Self-Test (POST) Errors and fixes. • Click here for HP Dynamic Smart Array RAID Controller User Guide. • Click here for HP Smart Array Controllers for HP ProLiant Servers User Guide. • Click here for HP Smart Array Controllers for HP ProLiant Gen9 Servers User Guide. • Click here for Configuring Arrays on HP Smart Array Controllers Reference Guide. • Click here for Array Configuration, Diagnostic, Storage Administrator and SmartSSD Wear Gauge Utility Software and User Guides.
Feb 15, 2017 | HP Computers & Internet
I have 4 hard disk connected one win server 2003 R2 standard , one of the hard disk is flashing orange and green but others hard disks is blinking green , so could i have a solution ?
It's a predictive failure. Check RAID. It needs to be 1 or 5. Reseat the drive and let it rebuild array. HP might ask you to flash it, if under warranty.
Replace it if amber light comes back.
Nov 05, 2012 | Computers & Internet
We have Prolian 570 Server with 4 X 18GB SCSI HDD with windows 2003 server installed. It was installed in 2004. Till then it was working fine . Recently there was some mishandling and It crashed and showed...
Good News and Bad:
Bad News - if the server was dropped really hard, the drives needles may be damaged and can not read the data on the disk(s).
Good News - If you know of a local company that do hard drive repair, they may be able to get the drive to work again to at least transfer the information to a new drive. (Check you local yellow pages for Data Recovery services.)
Hope you at least have a backup of the information that was on the drives.
Good Luck
C2Solutions
Feb 08, 2011 | HP ProLiant ML570 G3 Server
Dell power edge 1600 server
Is this hard drive in a RAID set? if it is, you will need to replace it with the exact same drive. After you do that, you will need to go into the RAID controller bios and initiate a rebuild.
Jan 10, 2009 | Dell PowerEdge 1600...
Active directory is rebuilding
if u edit settings in active directory and editing the rools
bake up your setting
and remove active directory
them stup it agien
Nov 06, 2008 | Microsoft Windows Server Standard 2003 for...
RAID6 problemme
Raid 6 will tolerate two simulatneous hard disk failures. So the posibility for data loss is very less. But the rebuilting steps defers for different server products like IBM and DELL. But normaly when u change a new hard disk the server will automatically starts the rebuilding process.
Jul 15, 2008 | Microsoft Windows Server Standard 2003 for...
Network and sql serivices failed during startup windows 2003 server os
Check all this----------
1-check the services (stop the service & start the service from the services)
2-check the firwall setting.
3-check the n/w card
4-Remoove the unwanted s/w
5-check pc for the viruses
I think this activity help you.
Mar 07, 2008 | Microsoft Windows Server Standard 2003 for...
Raid 5 failure
to recover your data is very easy. just slave your hdd to a system that is working fine and switch it on.after windows has succesfully loaded go to my computer you will see to hard drive.the slave hdd will be labelled B.double click on it go to my documents and copy all your filesand save it on your working hard drive.after copying make sure you remove the slave hard disk
Jan 31, 2008 | Microsoft Windows Server Standard 2003 for...
Abnormal Shutdown of windows 2003 standard
y cuse its sharing isssas to 1st off way to maby boots 2 max os on hard drive unless u want to fail soon do all your updates
Jan 25, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
