Question about Garden
WHEN YOU PULL THE PULLEY CORD IT SLIPS AND WONT START THE WHIPPER SNIPPER. IT DOESN'T GRAB ITS SLIPPING WHEN YOU GO TO PULL IT TO START. PLEASE HELP ME THAT WOULD
    Sergeant:
  • 259 Answers
The piece on the recoil that engages with the fingers on the flywheel is worn. You have to get another spool that goes in to the recoil it is usually plastic and it wears.
Posted on Mar 19, 2011
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
How to install pull cord?
take off cap then take out old pull cord once done get a cord long enough some will hanging out when recoil rewinds rope next there is hole in rewind pulley make sure you find it then hard part rewind spring on recoil till it stop hold tight the unwind 2 winds hold on tight next slip cord trough houseing and through pull hole put screw driver threw holes in threw rehousing that will hold in place the pulley not the cord take a lighter heat the cord up this will keep the knot in place grab cord remove screw driver from houseing hold cord tight pull cord until knot is seated next two pulley slowly let reciol wind rope in until it stops should be cord hanging out grab hiold of cord next to recoil hole pull out for two pulley revolution hold there install handle on rope tie knot heat knot with lighter your done cut off excess rope reinstall cap and completey down let me no if you have problem i will help im the red neck i like helping people
Aug 28, 2014 | Garden
Pope whipper snipper starter cord problem
The first thing you need to do is take the recoil cover off. There are several parts to a recoil and one or more parts may be worn and coming out of place then jamming.Replace worn parts if this is the case. If the cord pulls freely when removed then you may have a problem in the engine, try turning the flywheel by hand with the spark plug out. If it does not rotate there is something inside the cylinder or broken in the crankcase. If it is a 4 stroke engine you may have fluid above the piston,you will find this out when you remove the spark plug. drain the fluid from the cylinder and replace the plug you will be good to go. Good luck
Feb 09, 2014 | Garden
Whipper snipper wont start
when you pull the rope with the plug out do you get any gas coming out of the plug hole? It sounds to me like you have a faulty carburetor that is causing the unit to load up on gas stopping the piston from being able to move all the way with the plug in it
Jan 25, 2013 | Ryobi Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
What would have caused my talon whipper snipper to seize?
hello, lack of lubrication will make engine seize up,and also when the trimmer is hung up with the engine down the cylinder will fill up with fuel to where you cant pull rope,found this out myself,hope this helps,,
Feb 20, 2012 | Garden
Homelite hlt25cs centre of line spool stuck on whipper snipper
I had the same problem, the black knob on the bottom just slips round not unscrewing the bolt inside. I had to lever the knob off and then undo the bolt with a spanner. The re-threading instructions are in this manual : http://manuals.homelite.com/documents/2588
Aug 07, 2011 | Garden
My 2 stroke whipper snipper won't start
As with all 2 stroke engines,
1. Pump the fuel plug. 3 -5 times.
2. Turn the stop botton onto start.
3. Choke onto hot.
4. Pull the cord . Most important... dont touch the throttle trigger when pulling the cord. Wait until until it starts up.
If you do. (like it says in the instructions, your flooding the engine)
Works every time for me on everyone's whipper snippers.
Feb 09, 2010 | Ryobi Garden
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
