Question about Bosch 3.2 cu. ft. / 91 liter Upright Freezer Classixx GSD11133
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the 'superfreeze' on and the temp. went back to -18, but went up again when we switched the superfreeze off.The freezer door was shut all the time. Could you advise what the problem might be? Many thanks and regards, Robert Mansur
    Scholar:
  • 91 Answers
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Posted on Mar 22, 2011
Bosch Fridge Freezer (KAN62V40GB)suddenly started beeping and the temperature has increased. The normal alarm whent he door is not shut correctly is a continuous tone, however this is beeping like an
Check the condenser is clean and the fan running normally, Any excessive heat from under or behind is a sure sign the fan may need replacement.
Apr 28, 2014 | Freezers
Bosch kgu3201gb freezer
Try unplugging for 10 minutes to reset the cycle.
Oct 15, 2013 | Freezers
I have a freezer that does not keep tempreture. When I set it to -18 it will not get any warmer than -13 and if I try a super freeze it will take it the best part of all day to get to -18 and then it falls...
That you can get down to -18 suggests the compressor works and there is enough gas to get on with. Check the seals of the freezer for a heat leak- it should be able to grip a piece of paper in the door when it's shut. If the seal is bad then the paper will fall out or come with a gentle pull - order and replace the seal.
Sep 11, 2010 | Bosch Freezers
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Bosch fridge freezer stops working after approx 8 hours. Starts OK and freezes OK but next day it's warming up. Turn it off and back on again and it starts all over again and the problem reoccurs..
Found a solution at
www.reviewcentre.com/vt100228_start50_orderasc.html
Short out the dark blue and the dark brown wires that lead into the temp control dial. Everything now works. This bipasses a dodgy thermister or something. Of course this might not solve all similar problems but it does seem a common fault.
Dec 10, 2009 | Bosch Freezers
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Faulty Fridge freezer
I suspect you may have a faulty compressor! Do you notice if the compressor starts?
Feb 05, 2009 | Bosch Freezers
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Bosch Fridge Freezer Freedom Classixx
Hi there seems that the power supply unit has a fault and will need replacing suggestion to call an engineer.
Thanks J
Jan 01, 2008 | Freezers
Bosch 3.2 cu. ft. / 91 liter Upright Freezer Classixx GSD11133 Logo
862 people viewed this question
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
