Question about Bosch HMT9656GB Microwave Oven
The turntable is not working but I have power
  • 6,993 Answers
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.....
Posted on Mar 19, 2011
  • Elvis Presley Sep 02, 2013
    what another silly reply
My under cabinet microwave is not working correctly.
The possible reasons are: 1) The high voltage transformer is broken, 2) The magnetron is broken.
For the 1st problem, no power can be applied to the turntable.
For the 2nd problem, the magnetron is broken with no microwave can be issued.
Jul 14, 2015 | GE Microwave Ovens
Oven seems to be working with the exception of the turntable not revolving
Check that there is no damage to the plastic turntable rotor (i.e the part with wheels) underside the plate. Motor could be working but rotor missing or not connected properly, or damaged. Otherwise the turntable motor or motor driver circuit is fried.
Feb 04, 2015 | Microwave Ovens
I have a frigidaire over the counter microwave and the turntable quit working
Good Afternoon Friend, I appreciate your post!
If the turntable of your Frigidaire microwave has stop working, often the possibilities include one of three culprits:
  • Power Supply
  • Turntable Turned Off
  • Turntable Support Damaged
I always recommend resetting your microwave first before reaching out to a professional. You can do so by unplugging your appliance or flipping the circuit breaker for about ten minutes and then turn on your microwave.
Best of luck!-Z
Sep 07, 2014 | Frigidaire Over-the-Range Microwave
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Turntable sometimes works, mostly doesn't
It sounds like you have a jamming turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 28, 2009 | Microwave Ovens
Turntable will not turn
If everything works, light and micro heating.. then I have 4 possibles for you to check... 1st make sure you don't have a button that allow you to turn the turntable on/off... 2nd take the glass table out and check the center plastic spinner(pull it out) and see if its broken. 3rd your turntable motor is bad, and 4th the relay for your turntable on control board is bad... helpfully that will do it for ya.. good luck.. mike
Dec 20, 2008 | Kenmore 62622 Microwave Oven
Turntable doesn't turn
If you just purchased and Installed the microwave, I would call Sears and tell them what is happening, generally, it would still be under warranty if less than a year old. If its a countertop model, you may have to take it in, otherwise they should come to the home for the repair. I would also NOT indicate that you have looked at it as that would void your warranty.
Otherwise, it seems like the problem could be, a) touchpad , b) a relay or c) the main control board
Feb 02, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Turntable does not work
Need to check if you have power to the turntable motor. Either is has a bad motor or a bad relay on the control board.
Nov 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Bosch HMT9656GB Microwave Oven Logo
369 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
