I have a problem in with my Canon IR3170 printer.... it shows an error E000020 - 1a8 after every 10 to 12 copies and on the top right side it shows a shutdown key n i restart my printer and the problem occurs again and again......... what should i do now? plz reply soon
SOURCE: canon ip1880 printer service error 5202
Error 5202 means: UNRECOVERABLE ERROR. You need to return your printer to where you bought it and replace a new one if it is still under warranty.
Posted on Feb 20, 2009
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
  • 59 Answers
SOURCE: error message 0x610000f6 won't re-set.
>try to do hardware reset
>while printer is on unplug power cord at the back of it, press and hold # and 6 buttons on your printer, while holding the buttons plug back power cord, printer should initialise you can release the buttons after 10 secs or until you see semi full reset on the display, if the printer will not automatically turn back on press the power button, if it ask for you to set the region and laguage again then you have done the reset successfully
>this hardware reset should clear the error otherwise better contact hp
Posted on Sep 29, 2009
  • 1126 Answers
SOURCE: Canon mx330 Error 5100 Error 5100
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Posted on Nov 04, 2009
pineworks
  • 4041 Answers
SOURCE: system error e225
Canon imageCLASS MF4150 And ERROR E225 maybe others
Canon imageCLASS MF4150 Firmware Update V062 Windows 2000/XP/Vista/Windows 7(all x32/x64) from Canon Multifunction .
Hi there
This is because you need to update your Firmware,
So what I have don for you I have found the Update you need and I have put it on my website for you to download, this is a update for Vista / Win 7 / All 32Bit and 64 Bit.
Click Link = http://www.4all2sell.com/driver/Canon-MF4150_FirmwareUpdateTool_V062.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website is only there foe a limited time.
Posted on Apr 28, 2010
Why is system software of canon ir 3170ci not loading?
LOAD SOFTWARE WITH PRINTER DISCONNECTED FROM COMPUTER THEN CONNECT PRINTER
Aug 17, 2014 | Office Equipment & Supplies
How to connect printer to computer without installation disc
Download mode error comes in Canon Ir3170 only when the shutdown was improper. Kindly off the switch on the right side panel and plug out from complete power supply. then reboot the machine. It will work perfectly.
Dec 02, 2013 | Samsung CLP620ND Printer
How to clear e004 for ir3170
The SSR has a short circuit.The DC controller PCB is faulty.The SSR used to drive the fixing heater is found to have a short circuit.The error must be reset in service mode COPIER - FUNCTION - CLEAR - ERR.
Feb 21, 2013 | Canon imageRUNNER C3170I Color Copier
Need user and password of canon ir3170
here's the original disk http://www.precisionroller.com/manuals-for-canon-imagerunner-c3170u/products.html. Try these Default system password: user:7654321 , psw:7654321 Default technician password. 11111111 Control panel password: user: Administrator , psw: password
Oct 30, 2012 | Canon ImageRUNNER 3570 Copier/Printer
KINDLY CLARIFICATION FOR IR3170 CANON ERROR CODE -E000070-0002
this is error code for ITB HP sensor detection error. As possible solution you can try to clean the ITB HP sensor and belt rollers.
Call service, the copier needs to be dismantled badley... :-)
Hope that helps!
Sep 13, 2011 | Canon imageRUNNER C3200 Copier
ERROR E000020-0081 in the screem IR3170 C
these is developer/drum related error.
One of possibilities can be that you need to clean the drum patch sensor that reads the drum surface or replace drum unit.
The drum patch sensor is located above the drum unit inside of copier. For better understanding you will need service manual. emma.servis@gmail.com
Hope that helps!
Jun 08, 2011 | Canon imageRUNNER C3170U Color Copier
Ir3170 error code e000732-0001
This error code is a communication error between the Reader Unit and the Copier (Printer Unit). Shut down and un-plug the Copier. Unplug and reset all the connectors on the rear and sides of the copier. One interface cable is responsible for communication between the reader unit and printer unit. This may solve the problem. Possible the cable is defective see if cable or cable socket is damaged.
This error also can be caused by a defective reader controller/DC Controller or Main Controller PCB.
If the simple cable check does not solve the problem a service call by a Canon dealer will required.
Mar 16, 2010 | Canon Office Equipment & Supplies
This copy machine shows on the screen that "Close the lower rights cover" I checked the cover, it was closed. What should i do Machine :Canon Imagerunner400
Turn off your printer completely. Turn off your computer. Wait for a while, then turn them back on again. See if that works. If not, try removing the installation of your printer from your computer. Install it back again. If you do not have the installation disc, go to canon.com, you will find the drivers there.
Hope that will help!
Mar 08, 2010 | Canon imageRUNNER 400 Printer
Have ir3170 with error code E000020-008
the sensor inside the copier is dirty. you have to remove the drum and clean the sensor assmbly
Oct 13, 2009 | Canon Office Equipment & Supplies
Canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Jun 16, 2009 | Canon iR 2022 Printer
k24674
jasbo
jasbo
