Question about Guess G link watch #U65005L1 Watch for Women
How to unfasten the G-link in G10037L1 watch.??
I need a watch link for the guess U0379G4
Contact & Help ' GUESS Watches
guesswatches.com/customer-help
Get in touch, find your local representative and check for FAQs and watch care tips.
Guess Watch Links ' eBay
www.ebay.com/bhp/guess-watch-links Find great deals on eBay for Guess Watch Links in Wristwatches. ... Authentic Navy Blue GUESS Watch Extra Links and Bag Included (See Picture) Battery NOT ...
GUESS Watches, Parts & Accessories ' eBay
https://www.ebay.com > ... > GUESS Watches, Parts & Accessories Shop from the world's largest selection and best deals for GUESS Watches, Parts & Accessories. Shop with confidence on eBay!
guess watch extra links Google Search
Aug 07, 2017 | Guess Watches
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
Cam i get spare links for dkny clear links watch
yes Dkny will give you free links for your watch if you need them . DKNY watches are made by fossil watch company, you can contact them at this telephone number# 1-800-449-3056 to have watch links sent to you.
Oct 14, 2010 | Watches
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    How do i remove a link from the watch band?
    hi friend,
    step 1
    Measure the watch band's length. Every wrist size is different, and there's no need to remove all of the links when you may only need to remove one or two. Putting the watch around your wrist and pinching each link around it to see how much room you need gives the jewelry wearer a reasonable estimate.
  • Step 258782_65x95_aspect.jpg Open the watch near the link you want to remove. Link watches have several openings, so even if you open the wrong clasp, it can always be reattached.
  • Step 358783_65x95_aspect.jpg Flick the tip of your fingernail inside the clasp to open the extra links. Continue doing so until you have removed all of the links that are too big for your wrist. If you have short fingernails, try using tweezers or anything with a sharp edge that can easily unfasten a link. New watches tend to be very stiff, so it may take a little nudging, but the links come off. It will be obvious which ones come off and which ones don't by looking at the back of the watch band. The links that come off have a claw on the tip of each one and sometimes have the brand name on top of it.
  • Step 458784_65x95_aspect.jpg Put the extra links in a safe place. There may come a time that you either let someone else borrow the watch or your wrist swells and you need these links again.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If you can't get the links to open, visit a jewelry repair store. Workers there may be willing to help you adjust your watch for free. If you bought the watch from a retail store, the jewelry counter is usually required to adjust your watch for no additional cost.
    hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Kenneth Cole Reaction KC3367 Wrist Watch...
    The link on my mens guess watch came out about the sixth link from the watch face
    Call the customer service line and they will send you links.
    1-800-248-3775
    Jun 03, 2009 | Guess G85675G WristwWatch
    Need extra link for an Anne Klein 10-7977MPTT watch
    Yes you can, go to amazon and take a look: Amazon com Anne Klein10 7977MPTT watch link. Wish you best of luck.
    Cheers
    Jan 01, 2009 | Anne Klein 10 7977MPTT
    Watch Too Small
    Extra links for your Fossil watch can be ordered by calling Metro Service Center at (800) 842-8621.
    For all watches we offer up to two additional links. There is a $4 shipping & handling charge for all link orders. If more than two links are needed, you will be charged $3 for each additional link requested.
    Please note that each additional link adds approximately  inch to the watchband. Link quantities are limited and are not guaranteed to be in stock.
    Dec 28, 2008 | Fossil CH2331 Wrist Watch
    Guess G link watch #U65005L1 Watch for Women Logo
    104 people viewed this question
    Top Guess Watches Experts
    Ansel Alberto
    Ansel Alberto
    Dennis Fitzsimmons
    Level 1 Expert
    Are you a Guess Watch Expert? Answer questions, earn points and help others
