OIL LIGHT KEEPS GOING ON EVEN THOUGH THE CAR IS NOT LOW ON OIL
Sound like the sender unit. It is best to take your car to your friendly auto dealer or machanic.
Posted on Mar 19, 2011
2003 ford expedition low oil pressure light. car keeps turning off. what is going on here? what is it going to cost to replace the pump ?
replace oil pressure sender switch
change oil filter
then if no better
fit a sandwich plate oil pressure reader between oil filter and block
to get the engine oil pressure when running
Apr 26, 2017 | Ford Cars & Trucks
The oil sensor keeps going off even though the oil level is not low. I unplugged the sensor and it still goes off. Whats causing this?
rpm drops at redlight when slow down.....lower rpm equals lower oil pressure...if it comes on when ur doing 50 mph and stays on its a problem...if it comes on at stop signs then goes when u take off its ok.....but keep a check on ur oil ne ways
Sep 30, 2015 | Boating
The oil light keeps on flickering even though I checked the level and it's at the correct level. I even checked all other levels for all other fluids and they are all correct. What can be the reason that...
There are a number of reason that could cause this: bad sensor, low oil pressure, wire rubbed and grounding out.
You need to screw out the oil pressure sensor and screw in a pressure guage then crank the car and observe the guage. It should stay above 20 psi at all times.
Does it flicker when idling or driving or both?
Nov 05, 2010 | 2000 Plymouth Voyager
The oil light keeps coming on with a bell
If your oil gauge if you have one reads good pressure, more then likely you have a bad sensor, if you just have an oil light, take it to a repair shop where they can do an oil pressure test. Have it check, low oil pressure can cause major engine damage.
Jan 05, 2010 | 2000 Dodge Grand Caravan
My low pressure oil light keeps coming on when i stop and i just got my oil changed. The oil is not low. What could be the problem?
That means LOW PRESSURE , not low in volume. Pressure is measured in PSI. The reason that your light comes on when you are at a stop is because your engine goes to idle at a stop and would normally have lower pressure. That doesn't mean you should get a low pressure light though.. I would have it checked by a pro right away as this could be your first warning before a serious problem.
Hopes this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Oct 19, 2009 | 2003 Dodge Neon
1994 Lincoln Contiental DCL warning light keeps coming on.
uve entered the computer universe-my condolences--today everyting is connected in almost an imposible logic-u have an OBD 1 system-before 96-go hav car scanned to obtain a data stream to translate the codes that may appear-repair manuals explain these
Sep 08, 2009 | 1990 Lincoln Continental
Check oil light stays on even after a full oil change
The oil pan has a sensor in it that need to be replaced. It screws in and you may lose some oil.
May 09, 2009 | 2001 Chevrolet Malibu
Oil, brake fluid lights
the "brake" light in the dash is a warning light to indicate you have a serious problem with your brakes. Suggest you get it fixed immediatly.
thanks
Aug 20, 2008 | 1988 Jaguar XJ6
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
