Question about LG GSA-H55N DVD-RAM Burner
DVD writer does not read CD/DVD but can boot from it
  • LG Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Posted on Mar 19, 2011
My samsung dvd writer shown all songs dvd but when we are burn rewritable dvd the matter does not read by my writer dvd shown zero fill only. why please tell me that.
your CD ROM is combo drive which means you can read and write cd but only read dvd you will have to by DVD writer which is normally with all DVD rom
May 01, 2011 | Samsung (SW-208) CD-RW Burner
I bought my SAMSUNG DVD supper writer one year ago . I use Win 7 . It was good up to now . Now , My DVD writer cannot read DVD or CD . I checked plug of DVD writer , my PC told that DVD writer is still...
I would say you need a new CD/DVD. This one appears to have given up. These days, they are not very expensive. var fctb_tool=null; function FCTB_Init_3ebe2b55d0d94800b072c8db741693f5(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_0ef9312c3bb74669a836f0f462a4530a(t) { fctb_tool=t; start(fctb_tool); }
Jan 07, 2011 | Computers & Internet
This writer read only cd
I had the same problem.
It's the fault of writer .
So, I suggest you to buy a new writer.
Jul 03, 2010 | LG GH22LS40 DVD-RW Burner
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
MY HP 840i dvd-rw can read CD but can't read DVD
if you have cd writer and dvd rom then change your cd drive with cd/dvd writer because in the case of cd writer and dvd rom it gives error but sometimes the dvd play also but computer freeze from sometime and when we copy data then give us error messages i give you suggest to buy new cd/dvd writer
Jun 29, 2009 | HP Computers & Internet
DVD drive is not reading the Boot up disk
how many types of  bootable disks u hav tried,,,if d writer isdetecting d other ones den ur cd is faulty,hav u selected cd drive as 1st boot device or not
Mar 29, 2009 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    LG GSA-H55N DVD-RAM Burner Logo
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
