Question about Canon imageRUNNER 400S Copier
I have switched on my copier then i copyed it shows "switch main power off and on" E220 but it show repedenty
  • Canon Expert
  • 287 Answers
Hello vk,
Unfortunately I am not confident I can"FIXYA" but I can tell you what the code means and knowledge is power, especially if you have to call a tech. This code means the scan lamp (the light that comes on that illuminates the documents you wish to copy) is not performing as well as it should, if at all. When you turn on the copier, it goes through a series of self checks. One of those is the scan lamp. At start up, the copier turns the lamp ON and measures the brightness of the lamp. The copier will then turn the power up and down until it finds the target brightness it needs to give you good copy quality. Your copier can't adjust the power to the lamp high enough so you get this code. Remember it IS a light bulb and therefore will weaken/fail with time.Check to see if the lamp comes on by lifting the document feeder and observe if the lamp comes on when you power up the copier. If not you need a new scan lamp. If it does then I can assure you it has weakened with time and still may not be able reach the brightness necessary to hit the target. But there are things you might be able to do to temporarily help. NOTE!!!! UNPLUG THE COPIER for what I am about to suggest. Ok, at start up, the lamp comes on and shines UP and illuminates a plate that you can't see called the "standard white plate". It is the referrence the copier uses to know what "perfect white" is.When it gets dirty, thats a bad thing. Also, the 3 mirrors that reflect the light may be dirty.Also bad. Remove the large platen glass (take out 2 screws and cover on the right) and use a soft cloth to clean the mirrors by manually pulling the scanner assembly to the right. Soft cloth, damp with just a tad of window cleaner. Follow with a clean dry cloth.Now here's where you have to use you minds eye. Clean under the area that the lamp goes to when it is "home" and does its check. It shines"UP" , so its "under" what you and I see. This is the standard white plate area. Clean is good so when in doubt just clean and clean. No excess moisture, squeaky clean, dry when you are done. as many clothes as it takes.Treat it all like a window you want to see through. This process may buy you some time. But again, if the lamp is not coming on at all then ther is no point.Except the new lamp you buy will not be stressed if you clean the "optics". And I suggest you have a tech replace the lamp if it indeed needs replacement. Good luck and take care ! SPINAL
Posted on Mar 19, 2011
C-3725 trouble code
The fusing unit in side machine has reached a very high temp. This is the unit which fuses the toner to the paper the hot part upper right hand side of the machine. to reset follow:
Utility
1.Power off the machine using the main power switch inside front door leave sub power switch on that's the one on the op panel side.
2. Hold down the Utility/counter button.
3. Power on using main power switch and close the door.
4. wait for screen to show trouble reset touch trouble reset chk for OK
5. turn off main power switch, wait 10 seconds then power it up again. it should restart and go ready to copy. if the code comes back do not reset the machine again. It is informing you there is a problem get it looked at.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 01, 2014 | Konica Minolta KONICA BR BIZHUB C451...
Code error e54 copier.i need the reset codes
- Possible Causes -
· Thermistor short
· Defective ac drive board
· Defective main board
· Fusing harness shorted
To reset code :
1. Turn on the main switch.
2. Enter "71" by using the numeral keys.
3. Press and hold the Clear/Stop key until a dot (·) appears in the top left
corner of the Copy Counter and then release it.
4. Press the Clear/Stop key again and then press the Lighter key.
NOTE: "5" will blink in the Copy Counter to show that the SP mode has
been accessed.
5. Enter the desired SP mode number using the numeral keys.
When the E52, E53, or E55 conditions occur, for safety reason
they cannot be cleared by turning off and on the main switch. The
following procedure must be performed to clear these service call
conditions:
2. Turn DPS 101-1 on and off.
3. Turn the main switch off and on.
Jun 16, 2011 | Ricoh FT3713 Copier
My copier uses ricoh 320 toner, it is black en white and its displaying error code e 54. what are the reset codes.
- Possible Causes -
· Thermistor short
To reset code :
been accessed.
When the E52, E53,E54 or E55 conditions occur, for safety reason
conditions:
Can't get it to make copies. I need it to show "letter" size when choosing the size parer...it shows A4.
You may have a piece of paper jammed behind the paper tray? I would take the paper trays out of the copier and look inside to see if there is paper jammed toward the rear of the copier..... There are switch's that till the copier what size paper is in the tray. It can also be a small tab on the back of the paper tray is not adjusted correctly? Good Luck
Apr 05, 2011 | Canon NP 6230 Copier
IR2318L CANON COPIER IS SHOWING CODE E000003-0000 AND HAS STOPPED COPYING,WHAT COULD BE THE PROBLEM?
Heater temperature error (abnormal drop; low-temperature detection)
The main thermistor reading is lower than 140°C when paper is moved.
Main cause:
The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact
or has an open circuit; or, the fixing heater is faulty). The main power
supply PCB is faulty. The DC controller PCB is faulty.
Caution:
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. State
Turn on the power switch, and clear E002/E003. Thereafter, turn off and
then on the power switch. Does the fixing heater operate?
NO: See "The fixing heater fails to operate."
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Feb 02, 2011 | Canon imageRUNNER 2200
COPIER FLASHING F5
Hallow there. if you press copy key it should show 02 on the display meaning a problem with copy lamp. Please check the optical unit area for the following;
  • Check that the copy lamp board is well connected to the main board .
  • Check that copy lamp is lighting.
  • Check the document glass is well locked with the white part secured with screws.
If all the above is okay, then switch it on and work.
Jan 07, 2011 | Sharp AL 1631 Copier
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
WHEN I SWITCH THE COPIER IR 2800 .IT SHOW;S ME ERROR E000220-0001 HOW DO I CLEAR THIS ERROR
E220
0001 A fault is detected on the inverter PCB for the scanning lamp.
Main cause The inverter PCB is faulty. The reader controller PCB is faulty.
Action
1. Wiring
Is the wiring from the scanning lamp to the reader controller PCB normal?
NO: Connect the connector firmly, and correct or replace the wiring.
2. Inverter PCB, Reader controller PCB
Try replacing the lamp inverter PCB. Is the problem corrected?
YES: End.
NO: Replace the reader controller PCB
Pls. rate
May 11, 2010 | Canon Office Equipment & Supplies
Error code definition
All I can offer is From Canon:
Problem :
The machine displays an error code of E220. The code only displays when copies are made off the glass. Originals copied using the Document Feeder do not cause the code to occur.
Solution :
Unplug the copier and remove the Copyboard glass. Move the scanner manually and check to see if the Scanner Home Position Sensor Flag is coming into contact with the Inverter Pcb, or any of the wiring. Contact with the flag may be causing a short during Scanner movement when copying from the glass.
Problem :
Error Code E220-0001 occurs after replacing the Lamp, Inverter PCB and the Reader Controller.
Solution :
Check and verify the 24V supply to the Reader Controller from the Main Power Supply (Switching Regulator) is present. It is possible that one of the loads on the DC-Controller can take down the 24 volts. Remove the 24volt loads off the DC-Controller and connect the connectors one by one to locate the short or defective load.
Apr 14, 2009 | Canon imageRUNNER 2200
E800
Hello
E800 means : E800 Auto power off circuit problem. Main switch or DC controller
Feb 08, 2009 | Canon NP 6050 Copier
Canon imageRUNNER 400S Copier Logo
115 people viewed this question
old marine
old marine
