SOURCE: install games on samsung D900, says unsupported file format
finally made it work! allow me to share how i did it for others who still cannot make it work:
1. first edit the "java world\options\network settings\APN" to "Internet" with proxy set to "disable"
2. then connect PC Studio to check if D900 is connected, if connected then close PC Studio.
3.
if D900 seems to be not connected, reboot phone, remove usb and
reconnect and repeat step 2 again. if possible check that Softick PPP
is closed and not in "task manager\processes". If it is in there, then
end the PPP process and then repeat step 2 again.
4. if step 2 is successful and PC studio is closed, type #*536963#.
5. then run Softpick PPP and check if it has a connection such as \Device\ss_mdm0. If no connection, repeat step 2.
6. if step 4 is successful then activate Softick PPP.
7. Enter Serial Java menu #*5737425#, and choose PPP UP and then USB.
8. Open Uploader and add the .jad file you wish to upload.
9. Then on Serial Java menu, choose "serial download" to start the download process.
SOURCE: INSTALLING JAVA GAMES ON SGH-L760
Great news guys...i manage to
install games from my computer...using the cable...got the following
instructions from a forum...bit tedious but its better than nothing
right?
http://www.zedge.net/forum/t/37784/g...700-it-goes/1/
it goes something like this...
"First you need the “Qualcomm USB” drivers and “BitPim”. Prepare the USB cable, but dont put it in!
Driver: www.rexnet.it/firmware/utility/qualcomm_usb_driver.zip (changed from the original coz it didnt work for me)
BitPim: http://sourceforge.net/projects/bitpim
a. Unpack the drivers to a folder (exp. Desktop), but don’t install it!
b. Install BitPim.
1. You must entering follow code into the phone: *#0523#
2. [9] common >> [6] USB Configuration >> [2] Qualcomm USB [*]
--> Qualcomm USB Configured.
Plz Reconnect the Cable.0
3. Now put the USB cable in the phone and Pc.
--> Windows found a new hardware.
Install the hardware manual and chose the Qualcommdriver folder.
Now go to the Hardware manger ->Modems->Qualcomm, you must know the port number.
4. Open “BitPim” and configure the software for your u700.
Phone type: Other CDMA phone
Com port: *look at step 5*(you can Browse, but chose the right one!)
And press “OK”
5. Start “BitPim”, go to the menu “View” and active “View Filesystem”.
6. Klick on “Filesystem” (left in BitPim).
Now can you see a blue folder, open the folder (press on “+”).
--> … retrieving
7. Now put the games (jar and jad files) in the follow folder “Games” (Media->Games).
8. Disconnect the USB cable from the phone.
9. Leave the Qualcomm menu and entering this code in your L760: *#6984125*#
Now are you in “Admin setting” menu.
a. Select the menu [4] Internals (Master Key: *#9072641*#)
b. Chose the menu [7] Storage settings
c. Update media database, Update Java DB and Create AX Dat File.
That it’s!! (You can leave “Admin setting”.)
Important: DON’T delete the games with the mobile phone, you must delete the games with “BitPim”.
How to install Java games on the Samsung L700 without any software or drivers
(I've done this on a pc with Windows XP and don't know how well it would go on any other OS)
In the phone Menu select
'Settings'
Then select
'Phone settings'
Then
'USB settings'
And choose
'Ask on connection'
Plug the Phone in to the PC with the USB cable
On the phone selct
'Media player'
On the PC wait until it detects the phone and select
'Open the device to view files'
Open the folder
'Phone'
You should see the folders: images, Other files, Sounds, Videos
Create a new folder and name it
'Games'
Put any game you want to install in that 'Games' folder
Two things need to made sure of when copying over the games. Firstly make sure you have the *.jar and
*.jad files for each game, if you don't have the *.jad file, you can download a jad creator pretty easily, just type it in Google. Secondly each game has to be in it's own folder, if you just dump all the *.jar and *.jad files directly into the 'Games' folder only the first game installed will work (Poorly too).
Unplug the phone
Now on the phone dial the code:
*#6984125*#
Select 'Internals' (Number 4)
It will ask for a master key it is:
*#9072641*#
Select 'Storage settings' (Number 7)
Update Java DB (Number 2)
Now on the phone enter the code:
*#6984125*#
*#9072641*#
Turn the phone off
Turn it back on
*#6984125*#
*#9072641*#
The games should now be installed with no problems, I know it's bit repetitive but this has worked the best for me.
(Note: if you delete a game on your phone and then want to reinstall it later you will have to give that game a different folder name before you put it in the created Games folder. It won't allow that folder name again even though you've deleted it)
SOURCE: Unable to install games in samsung s3310 metro mobile
move to this links...
to install games...(.jar and .jad)
http://3310metro.blogspot.com/
to download games:
http://3310goodies.blogspot.com/
to install themes..
http://samsung3310.tk/
i tried all and iam enjoying with my 3310 with live themes,games and lot
of stuffs..cmon lets play
"dont forget to rate solution"
