Question about Logitech Webcam
No find match device please insert camera first
  • 902 Answers
You need to go to legitechs website and re-install the drivers. simple as that. i would link the drivers for you but not sure what model you have please let me know if this helped
Posted on Mar 19, 2011
What is the maximum size sd card (Gigabites)?
speed class choices.
about compatibility with host devices before choosing your card, it is important that you understand how to use your memory card to it greatest ability. sdxc memory cards and devices (digital cameras, video cameras, laptops, etc.) are now available. learn how to use your new sdxc memory card to optimize its performance.
confirm compatibility before inserting your sdxc memory card, confirm the device is compatible with the sdxc standard by locating an sdxc logo on the device or referring to the device's user manual or manufacturer information.
understanding backwards compatibility
  • sdxc memory cards must only be used with sdxc devices.
  • sdxc devices can use sd memory cards, sdhc memory cards and sdxc memory cards.
  • sdhc memory cards can be used with sdhc devices and sdxc devices.
  • sdhc devices can use both sd memory cards and sdhc memory cards.
  • sd devices can only use sd memory cards.
http://www.tomshardware.com/charts/memory-cards,39.html
the link above has several chart on sd cards.
Jan 20, 2015 | Cameras
I have tried downloading 2 drivers for Quantum PC Camera QHM 500 LM but nothing is working can i get any software where it automatically detects the drivers and download it ?
Hi! Here's some hint. I presume you are using Windows 7 or higher operating system version. Make sure you are connected to the internet. Detached the pc camera, remove completely the old drivers at Control panel, device manager, camera, so on... Before removing however, please take note if the drivers for the pc camera marked Warning (usually yellow or read exclamation). Now, insert the pc camera again until it is detected when ask to insert cd/dvd driver select online search driver instead let the online intervention do the crawl. Else download the specific driver that matches your pc camera. Take note when installing drivers do not attached the device yet until you are told to do so or when it is finished installing. Try plugging it to other usb ports available. An updated operating system may also solve driver issues. Try also installing the pc camera on other pc-unit with different operating system.
Mar 07, 2014 | Quantum GoVault Cartridge With Docking...
Asus no camera device found
You can download the Asus camera driver (please make sure that it is match with your Asus laptop model) and install it because it may trigger the laptop to look for the camera. Probably the camera is failing, but it is very rare.
Dec 25, 2013 | Computers & Internet
Card error when i inserted the sd card
The error may be caused by ...
- the SD card is corrupted
- the camera doesn't support the SD card's size or format
- the SD card contacts (to the camera) is faulty
- the SD card has (content) specifications (e.g. read/write speed) that is not compatible with those that the camera support ... e.g. camera expects a Class 6 or higher, and your card is Class 2
Check the camera manual - specifications, to see if it matches and support the SD card (format, size, storage capacity, etc.)
Check the SD card specification to see if it matches.
Nov 04, 2013 | Fuji FinePix S2000hd Digital Camera
Windows 7 refused to update. Windows 7 refuses to
  1. Do one of the following:
    • Connect a camera to your computer by using the camera's USB cable, and then turn on the camera.
    • Connect a portable device that contains pictures or videos to your computer by using the device's USB cable, and then turn on the device.
    • Insert a removable flash memory card, such as a Secure Digital (SD) or CompactFlash memory card into a memory card reader.
    • Connect a scanner to your computer by using a USB cable, and then turn on the scanner.
    • Insert a data CD or DVD that contains pictures or videos into your CD/DVD drive.
  2. In the AutoPlay dialog box that appears, click Import pictures and videos using Windows.
  3. To change the settings that are used when importing pictures and videos, click Import settings in the Import Pictures and Videos dialog box.
  4. Change one or more settings in the Import Settings dialog box, and then click OK.
  5. Click OK to restart Import Pictures and Videos. Type a tag in the Tag these pictures (optional) box, and then clickImport to import your pictures and videos using the new settings.
    For updates make sure that the time and date are correct, if it doesn't match what time it actually is , it wont update, and make sure your OS has been activated
Aug 29, 2013 | Dell Dimension 4700 PC Desktop
Memory Stick Error, PLEASE HELP!!!
Does any other Sony memory stick still work in your camcorder? If yes, means memory stick isn't match with this camcorder. Use Sony memory stick.
Jun 09, 2008 | Sony Handycam DCR-TRV20 Mini DV Digital...
Installing battery
The battery on a SD550 is a 3L model, and it goes in one way.
The bottom of the battery has a set of copper looking contacts, and inside the camera in the battery compartment is a matching set of copper contacts, all you need to do is insert the battery to match the contacts and you should be good!
Jan 15, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Download disk
Hi , this is my problem for my camera before : Open control panel click scanner and camera icon /on the power of the camera insert the usb , sound beep alert camera icon will appear ,add camera device then follow instruction on screen .
check also device manager .goodluck
Jan 10, 2008 | Canon PowerShot A560 Digital Camera
Linking my canera to the TV to view the pic's
Playing Back images/Video Clips on TV You can also playback your images on a TV screen. Before connecting to any device, make sure to select NTSC/PAL system to match the video output system of the video equipment you are going to connect to Vivicam 5340s, then turn all connected devices off. 1. Position Vivicam 5340s on the cradle. 2. Match the docking connectors and carefully insert Vivicam 5340s until it fits in place. 3. Connect one end of the A/V cable to the A/V terminal of the cradle. 4. Connect the other end to the A/V input socket of the TV set. 5. Turn the TV and Vivicam 5340s on. 6. Playback the still images/video clips. The method of operation is the same as playing back still images and video clips on Vivicam 5340s. I hope this helps:)
Aug 24, 2007 | Vivitar ViviCam 5340s Digital Camera
Logitech Webcam Logo
1,325 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
