Question about Genius GPEN F509 Slim (31100021100) Digital Pen
My cursor is shaking even though i know I've done a straight line.. and its going back to middle right of the screen.
98 acura integra dies while driving
might be a timing issue. check if your spark plug wires are seated correctly also you might have a dirty fuel injectors. a good cleaning might help as long as they are not leaking.
Mar 28, 2017 | 1998 Acura Integra
Tip
I went with this replacement screen when i cracked my original, I've also...
I went with this replacement screen when i cracked my original, I've also replaced my wifes iPhone 5 LCD screen so I've had some experienece.
Right off the bat, you need to take your time when replacing these. Any one thing can go wrong and thats where I feel a majority of the bad reviews for this product stem - people dont know what they're doing, rush it and cut, crimp, bend, or break something.
You will need to remove things from the original screen like the metal backing, clear plastic camera hole, rubber piece for ear slot, wire mesh for ear slot, grounding tape (attached to original screens metal backing), etc. Any decent youtube video will tell you this. If you want your replaced screen done properly, do this. You will need to add a straight edge blade to your tool arsenal, doesnt need to be sharp but a box cutter blade is ideal for working the screen out of the housing (just above the headphone jack is the place to work the blade in between the housing and the screen). Then use the provided plastic tool to work around the edges to fully remove the screen.
I wont lie, even with experience, after putting my new screen in, I had blue lines show up initially, I went back to the screen connections on the motherboard and rechecked them. After loosening the metal plate a bit the screen worked fine. I tightened it way too tight, drive them in so they're snug, not like they're keeping the wheels from falling off your car. You will also need a work area to keep track of all the little pieces, if you have parts left over you did something wrong. Also, when fitting the screen back into the housing, run your fingers down the side touching the screen and housing, with slight force, do not push on the middle of the screen!
What I didnt know - restart your phone after completion to ensure the finger print reader on the home button works! This thing is very sensitive and any loose connection will botch it. Not realizing this and figuring I did something wrong, I spent way more time then i shouldve troubleshooting... All I needed was a fresh phone restart and finger prints worked like a charm. PROVIDED this was my original home button, that was attached to my original motherboard. IF YOURE REPLACING YOUR ORIGINAL HOME BUTTON FINGER PRINT ID WILL NO LONGER WORK!
This apple replacement parts worked like a charm for me, and for $30 thats pretty awesome. Becareful, watch a couple youtube videos, and good luck! Apple IPhone LCD Screen Digitizer Assembly Replacement Parts Wholesale
on Apr 10, 2017 | Electrical Supplies
When I rollarblade, the front wheel shakes a lot.
I bought this stroller at toys are us. And the front wheel warbles when we are not going straight. The inner part is not right. It isn't even a year old. What can be done.
Jul 06, 2012 | Baby Trend Expedition LE Jogger
The page scrolls up and down - somtimes even jumps up and down - when the cursor is nowhere near the right hand of the screen where the vertical scroll bar is.
It is possible you might have picked up a virus, or a bad device driver. Try a system restore taking the computer back in time before this happened, may resolve the issue.
Mar 24, 2012 | Acer Aspire One PC Notebook
I am a rookie user of IP 2. I was composing a critical email. I had need to move my cursor back to where I had made an error so I tapped the screen to move it to the appropriate spot (is there any other...
If you've done NOTHING else since you deleted the message, you can utilize the "undo" feature of the IPhone (been around since IOS 3). Hold your phone FIRMLY in one hand and shake it around a bit. That should bring up a menu, on which you select "undo". If you've already tried typing/doing anything, chances are it's not going to work, but it's worth a shot :)
Aug 22, 2011 | Computers & Internet
Can't get full screen even though maximize
TRY USING MOUSE CURSOR TO WIDEN SCREN BY EXPANDING WIDTH AND HEIGHT. ONCE DONE RIGHT CLICK ON WINDOW AND CLICK "REFRESH" CLOSE WINDOW...THEN REOPEN ND SEE IF IT OPENS TO PROPER SIDE.
GODD LUCK
Oct 19, 2010 | Sony VAIO VGN-N325E Notebook
Double-Cursor to Obsolete
Is this driver certified for Vista? If it worked partially before and fails completely now, roll back to the previous driver. Compatibility is the key.
Aug 03, 2009 | Adesso (CYBERTABLET12000) Graphic Tablet
Line down middle of the screen-resolution is different on sides
Computer parts can sit in warehouses and be on trucks for a long period of time. Unfortunately that means things get banged around. Sometimes they don't even work when they come out of the factory. I suggest exchanging the monitor for another one. It could also be your video card. Easiest way is to exchange it and it's free to exchange.
Jul 07, 2009 | LG Computers & Internet
Sticking cursor
these type of problems can be caused by a wire crossing the line of sight between the mouse and the receiver check
you have no cables in the middle of them even a usb cable can cause it to respond this way
also spyware and viral activity does this to
Nov 04, 2007 | Logitech Cordless Mouse
Acer Tablet C300 Series - Cursor moving to Left
I?ve had a couple of Dells laptops do this and without fail the cause was flaky touchpad/mouse drivers. I would suggest going to the Acer website downloading the latest drivers for your mouse. If that fails try removing the driver and running with the Windows default drivers, that what I?ve been doing successfully on my company laptops for several years now. Acer driver download page, the web site is really slow so be prepared for a long wait. The closest match was the C300 so I?m assuming these are generic drivers for the 300 series. Use the pull down menus and select the following: -Select Product Line = Notebook -To the right of that select TravelMate C300 (way at the bottom) -Make sure English is selected and click on the search button. Once the drivers page opens go down towards the bottom and load for TM C300 touchpad drivers Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 19, 2007 | Acer TravelMate C302XMi Tablet PC
Genius GPEN F509 Slim (31100021100) Digital Pen Logo
70 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
