Question about Onkyo Audio Players & Recorders
The DAB on my CR-515 has stopped working and says 'no stations'. What's hapened?
Just had the same problem. Had a power cut in the area and it's wiped everything on my CR515. You need to reset it to the factory defaults.
On the actual stereo (not remote), switch it on, then hold the stop button followed by the on/off button. Clear will appear on the screen and it'll then turn itself off, When you turn it back on, it'll ask you to wait. Your DAB should be restored.
Bear in mind, this will reset all your presets and any other preferences you have set on your system. It should also, however, restore your DAB.
Posted on Apr 19, 2011
The radio channel numbers on my Suzuki S-Cross are 'greyed out' and do not operate
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Aug 15, 2016 | Suzuki Cars & Trucks
The dab is not working
what is a dab???
Nov 26, 2014 | Cars & Trucks
Dab signal
I suggest you scout around the neighbours for a DAB you can borrow to test the signal in your usual place. Your own radio could be faulty.
One of my DAB radios worked fine on FM even though one day it just stopped working on DAB for no apparent reason. The board to repair it is priced not to sell...
Sep 17, 2017 | Audio Players & Recorders
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
My Pure Evoke 2 Dab radio has stopped working, it has power but can't get sound stations or anything ...what do i do?
I've got the same problem, from working perfectly to suddenly nothing. "No stations available". Please let me know if you get an answer.
Sep 02, 2010 | Audio Players & Recorders
Philips MCB204 problem with tuner , DAB and USB
Is the MUTE button activated? Press once to ACTivate or INactivate
Apr 07, 2010 | Philips Audio Players & Recorders
Teac CR H250 plug into arial
The only thing that would damage DAB reciever is lightning hitting the arial. But all you have to do is unplug during a storm. You might get a better reception with the £100 job, but I think he was a conman!
If in doubt read the instructions!
Jan 29, 2010 | Audio Players & Recorders
Setting the reset stations on a DAB radio
I used lateral thinking! looked at the instructions for my other matsui DAB radio and worked it out from there. With this Ferguson model you have to find the station you want manually and then press one of the preset buttons (it only has 4 but these are enough for me)
Jan 06, 2009 | Audio Players & Recorders
Lodik dab 3006 radio
how to install a driver
Apr 30, 2008 | Computers & Internet
DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Feb 22, 2008 | Audio Players & Recorders
766 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
