Question about ASUS M4A77TD Pro Motherboard AM3 AMD 770 ATX RAID SATA Gigabit LAN (90-MIB9S0-G0EAY00Z)
MY NOTE BOOK DOES NOT BOOT? - ASUS M4A77TD Pro Motherboard AM3 AMD 770 ATX RAID SATA Gigabit LAN (90-MIB9S0-G0EAY00Z)
  • 187 Answers
Try to do this:
- remove the battery and charger (everything connected to the pc) then press the power button for 1 minute..
- plug back in the charger
- after few secs try to turn it on
hope this helps :D
Posted on Mar 19, 2011
My computer froze so I turned it off and when i went to turn it back on, it says no bootable disk insert boot disk and press any key. Ive tried everything but it wont start up. And there is no disk that...
Sounds like your hard drive is going bad. Best thing to do is to take it to a shop and ask them to check your hard drive. Or, if at all possible plug it into another PC externally with a external HDD kit and check it with programs such as crystal disk info.
Best of luck
May 23, 2011 | Gateway M-7315U Notebook
Boot with usb device on acer travelmate 202t
If you are not able to boot from CD or DVD you can use portable DVD readers to boot your note book .
Dec 14, 2010 | Acer TravelMate 202T Notebook
My Window Xp on my mini note book a file has been corrupt file missing so it wont load windows
Try booting in safe mode.
Switch on you note book, while its booting press F8 several times, this should bring up a black screen with several boot options, choose "Safe Mode"
This will load windows shell programme.
Once loaded click on Start - All Programmes - Accessories - System tools - System Restore.
Select a restore point prior to when you first had a problem and let your pc do the rest.
If you can't do a system restore for what ever reason, you'll have to do a system recovery, this tends to dump your data.
Nov 13, 2010 | Computers & Internet
Unable to format, partition,ins. os and boot my toshiba TE2100..
The CMOS needs to be set to first read the CD or DVD drive before it reads the Hard drive. Once your XP disk is in the drive it will boot from the CD drive and setup the computer, The CMOS is acessed by turning on the computer and immediatly pressing either the deleat key or the F! or F2 key try each one till you get to CMOS then look for boot section. Set CD drive to first your HD drive to second.
Nov 09, 2009 | Toshiba TE2100 Notebook
I was trying to load ubuntu onto a spare hard drive i had lying around. i used my everex stepnote 1500 note book to load the system on to the spare hard drive. now when i turn on my note book without the...
You should install Ubuntu from inside Windows with the wubi program. When you boot you will have Windows as the default boot option and Ubuntu as a second option. Choose the Ubuntu installation to reside on the external drive. You will connect the drive if you use Ubuntu.
If you do not do that, reinstall ubuntu on the external drive and choose to write the boot sector for GRUB or LILO on the external drive, not on the MBR of the primary drive.
Hope it helps.
Sep 12, 2009 | Everex StepNote NC1500 Notebook
Acer 3100 boot freeze
boot frozen you may try
1) change RAM memmory or change the memories slot between one and another
2) check cpu fan works when booting
3) clean the dirty stuff through the way of cpu fan
if not fix, your motherboard hardware need to repair by the specialist
Jan 24, 2009 | Acer Aspire 3100-1405 Notebook
PXE-E61 Media test failure check cable my note book is asus f3f and when this massage appear i cant connect to internet.
That message is when you have your computer set to network boot. You can disable it in the bios or change the boot order to put network after hard drive. Press probably Delete when booting to get into your bios and look for Boot Order.
Jan 05, 2009 | ASUS F3F Notebook
Will not boot up ( acer aspire with vista basic)
0xa 0000000 is a hard drive error .. either your controller or your hard drive has failed ..
Dec 28, 2008 | Acer Aspire 5315 Notebook
No power - no boot
for this two resasons is there one is your power and other one is your ram in your note book can do change the both the thing for testing purpose . or check it the power adapter to other note book. after that you get it.
Jun 11, 2008 | HP Pavilion dv1000 Notebook
Eamils
Microsoft has a trouble shooting page that should help you.
http://support.microsoft.com/kb/813514/en-us
Feb 23, 2008 | Compaq Presario 5000 PC Desktop
ASUS M4A77TD Pro Motherboard AM3 AMD 770 ATX RAID SATA Gigabit LAN (90-MIB9S0-G0EAY00Z) Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
