Question about GE 26928GE1 Cordless Phone
My ge cordless 6.0 has very bad sound quality,you can barely hear anybody and the signal seems weak. It is a three unit set and I do have wi-fi and filters on all lines. This is a problem on all cordless phones in the house and I do not have it with corded phones. What can I do to fix the problem,this is the second set I bought to take care of this problem, Thank you for your help..............Dan
  • 131 Answers
SOURCE: ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Posted on Sep 30, 2007
SOURCE: programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Posted on Feb 21, 2008
mewms_14904
  • 1027 Answers
SOURCE: Model#25865 2 line cordless, will not rollover to second line
The handset should display which line is on hold, when the other line rings the handset operator would have to push the corresponding line/talk/flash button. e.g if line 2 is on hold and flashing, press line1/talk1/flash button.
consult manual
Page 30-31
Posted on Apr 09, 2008
  • 5 Answers
SOURCE: Cordless Handset fails to Link to main corded phone
Manual is here
http://www.home-electronics.net/ge/pc/IB/27957GE1_IB.pdf
linking instructions on p16
Posted on Jan 05, 2009
SOURCE: GE 6 0 Cordless phone model 28112EE3 A' I don't have the manual
Ge Dect 6.0 cordless
How do I retrive messages from outside phone what is the procedure
Posted on Feb 06, 2009
Zte tablet model k88 wont connect to wifi
Weak wifi signal or defective tablet or router.
Jun 27, 2017 | Tablets & eReaders
Help with signal interference
I assume you are referring to the WI Fi part of your router.
Go into router settings and change the channel from AUTO to manual and add three or six to the lowest available channel number .
If you have cordless phones nearby check they are not on 2.4 Ghz.
Also I have recently noticed that toy Drones operate on the same frequency of 2.4 GHz.
Try different channel numbers until you get no signal interference on your Wi Fi.
If the Router has 802.11AC you may be able to run wi fi on 5 Ghz with an USB 802.11AC adapter on your computer or laptop running on 5 GHz at 1.3 GB/s .
Dec 24, 2016 | Computers & Internet
The sound is weak. The max. Volumn is very weak. How can I get it louder.
In general, tablets don't have powerful sound systems. Some ear-buds will play louder than others, but don't expect any built-in speaker to play loudly. Try different ear-buds, that may help, or an external "amplifier".
Dec 07, 2015 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
I have to enter my password several times to get my kindle to log on. I always have to log on..the signal seems to be weak adjacent to the router. authentication failed is a normal response on my kindle....
your kindle device should be able to connect the network automatically , if this is not happening try adding the network manually.
1.First, make sure you are within range of the network you want to add, and that you know the network name and password (if required).
2.From the Home screen, tap Menu and select Settings.
3.Select Wi-Fi Networks to display a list of detected Wi-Fi networks.
4.Tap Join to enter network details.
5.Use the onscreen keyboard to enter the name of the Wi-Fi network that you want to add.
6.Once the Network Name has been entered, tap the Password box and enter Wi-Fi password / Network Key using the onscreen keyboard (if required).
Tip: Tap the 123 key to enter numbers or symbols. Tap the ABC key to return to the regular keyboard. Tap the Shift key (up arrow) to enter uppercase characters. Your password may include non-English letters (accents, umlauts etc.). To view accent options, press and hold a letter down, and accent options appear.
7.Tap Connect
Does all your wireless devices have weak signal issues?If so , Then problem may be with the wireless router.Try changing the wireless channel on the router by logging into the router interface page.
Authentication failed is the message u ll normally get when u enter the password incorrectly.
Aug 07, 2013 | Belkin (F5D7230-4) Router (587009)
Router strength is only usable in the same room. cannot use wi-fi in rest of flat
in case your router is strong enough, you can use wi-fi all around the flat. But as you described the problem, it seems either you have too rough walls, or your router is too weak to deliver the signal all over the flat, or your laptop has too weak antena.
So either you can try some other laptops to see if your laptop's antena is ok, or then a stronger router. To find suitable router, you should better ask either at any online store with wi-fi routers, or in local IT store.
Lucas
Jul 07, 2011 | Computers & Internet
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal.
This is a message that yahoo messenger usually tell the users when it detects a low internet connection. You are right with what you have mentioned about the weak wi-fi signal.
I have been receiving the same message because of my wi-fi signal but so far so good. I never have any problem with the quality of the sound in the call or any disconnection of the call except for the sloppy webcam. But, I understand the problem because I really do have a low signal at home.
Apr 02, 2011 | Yahoo Messenger
You may hear .. .. . . .
you have to change your channel type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
thern check signal strength.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 23, 2009 | Yahoo Messenger
Poor quality of voice and can't hear the
My DSL filter had gone "bad" I needed to replace the inline filter.
The suggestion was also to move the base unit away from the kitchen area because of all the technology that I had happening in one area.
Jun 11, 2009 | Uniden Cordless Phone
Asus 802.11g wi-fi only detects network when connect a cable to the external antenna. what should i do?
It seems that the signal reaching your modem is weak or it getting blocked by some electrical equipment, try relocating the antenna. But first try it on another PC at a different location to confirm that wi-fi is working properly..............sodeep
May 08, 2009 | ASUS Wi-Fi@HOME (WIFIG80211G) 802.11g/b...
GE 26928GE1 Cordless Phone Logo
41 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
