Question about Pioneer Televison & Video
Volume is fine but picture is to blurry to see Menus, and wont change channel without remote. do not have remote
  • 902 Answers
Need the model of the tv. but with a blurry picture on a projection tv its means that your color board or color wheel is going bad. but more likely and much cheaper would be a bad bulb or ballast for the bulb. that will be your solution. hope i helped let me know.
Posted on Mar 19, 2011
How do I get a Crosley 42" hi def tv to change
I can't speak with knowledge about the Crosley brand, but almost all regular TV brands have buttons on the side for Function or Menu On/Off, Volume +/-, and Channel +/-. The volume and channel buttons are used to navigate the menus and to adjust the settings.
If you can't work this out by experimenting with the buttons, or reading the user manual, then perhaps you should just go out and buy a universal remote that works the Crosley TV brand.
Hope this helps.
Sep 06, 2014 | Televison & Video
Can't find the ok button on AWA tv to select auto tune without a remote
You have to go into the menu to change settings.
There you find what you are looking for.
find channels and auto tune and ok.
Jul 17, 2014 | Televison & Video
TV flips through menus, changes channels, and changes volume without any buttons being pushed
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
May 26, 2017 | Hannspree ST42DMSB 42 in. LCD TV
My tv was playing fine when I turned it off. Later, I drop the remote prior to attempting to turn the tv on.Tv will not turn on with or without remote.
OK, YES you CAN turn on the TV without the remote, in fact you can do nearly everything that can be done on your remote, on the TV itself, NOW look, CAREFULLY around the edged or sides of your set, you will find there are "Buttons" usually there are 6 - 7 Buttons, if you look carefully at them you will see they are marked, usually with a Volume Up & Down, word, or symbol, A Channel Up & Down, buttons a Menu, an Enter, and an ON/OFF button, & sometimes others. Now To turn on, Press and hold the Power button, the TV will Turn ON, you can change Channels, with the Channels, and Volume, with the Volume ones. The Menu button, will allow selection to all the other sub menus and settings. IF you need to get a remote, Please, get an original, it may be more hassle, it may take longer to get, it maybe costs more... BUT IT WILL WORK. Universal remotes, well, read through a few posts dealing with them, and you will see what I mean. IF you MUST get one, absolutely ensure that it performs every function the original one did, or you can have many headaches.
Apr 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv is stuck on aux
Push the "menu"button on the front of the unit. That will get you into the menus to adjust any setting, like caption, language (but that one is tricky if yours happenend to be set to a language you couldn't understand :P), brightness settings and the such are there too. The one you are looking for is "input", change THAT setting. with either volume up/down +/-, or channel up/down (+) (-). In the menu, change the "input" selection to cable or whatever you are trying to watch on the tv.
Hope this helped some, if so, please rate, thank you!
Channel setup
V-Chip Setup
Caption
ect.
Using the Volume + and - along with the Channel up (+) and down(- ) key's, will give you all the adjustments you may need without a remote control.key's, will give you all the adjustments you may need without a remote control.
Feb 02, 2010 | Durabrand DWT1905 TV
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Hi, I have a RCA 27" console color tv without the original remote. It has the RCA cable ports. I bought a Toshiba DVD and it needs the TV to have an external channel which can only be set by remote? Is...
After market remotes only work the most basic of functions - ie., volume channel changes , on/off. They do not get into menus, change inputs, etc. If you can change channels on the console tune it to 3 or 4 and get an rf adapter for your dvd player outputs, set it to one of those channels, and connect to tv antenna input. Ir will work but the picture will not be as good as it can be.
Mar 03, 2017 | RCA G27647 27" TV
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
