The thermistor isnt installed would that mean that the unit wont heat?
    Master:
  • 403 Answers
Yes, no temp to read
Posted on Mar 19, 2011
I have a Fujitsu ASTA18LCC with 3x operation and 4x timer light code.
This is an "outdoor temperature thermistor open/short" error.
An easy and cheap fix but you will have to buy the part from Fujitsu.
Mar 16, 2017 | Fujitsu Heating & Cooling
What call service 3 in Panasonic kx-mb1900
CALL SERVICE 3" means that the temperature of the fuser does not rise up to or exceed a constant temperature.
The temperature is monitored with the thermistor inside the fuser and detected with the voltage input into IC 300-D19
Apr 26, 2014 | Panasonic KX-FL611 Plain Paper Laser Fax
Xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until after I...
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
May 10, 2012 | Xerox WorkCenter 4150 Black and White...
When I turn the copier on: Error code E000 appears and it turns off automatically. What's wrong?
e000 means the machine not sensing the heat by his thermistor within a presetted period in "FIXING UNIT"
the main reasons are
check every connector of fixing unit.
check heaters lamp in upper heat roller in fixing unit.
check thermostate and clean/replace thermister.
if lamps,connections and thermistor and thermostate are ok then power control pcb may be faulty
Jan 06, 2011 | Canon NP 6551 Black and White Copier
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Jan 05, 2011 | LG WM2487H Front Load Washer
What does f-03 mean?
Hi
Error F03 in Hotpoint washer means that the thermistor is open. When thermistor turns bad it will not let the water to heat or in some cases will boil the water to extreme temperatures. You’ll need to replace the thermistor to resolve this issue. The thermistor is located in the motor control unit. Inspect the element if its open circuit, it should read 1500-1800 ohms on Rx1 on the multimeter, if not then element is bad. To check/replace the element remove the lower rear panel. Hope this helps...
Daniel
Sep 01, 2010 | Hotpoint Washing Machines
Problem is sc541
This is a fusing unit error code. Most likely one or both of the thermistors have failed. The fusing unit is the part that gets hot just before the paper exits the machine. The thermistors are the electronic parts in the fusing unit that monitor the temperature of the unit. This code means that the thermistors are either not "seeing" or reading any heat from the unit or for some reason the heater lamps are not coming on. In most all cases it is the thermistor/s that have gone bad and are not reading heat properly. You will need a service technician to replace these. Should be less than $200 repair.
Good Luck
Dec 12, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
ERROR SC545
This error code indicates a fuser unit malfunction. Most likely it will at least need new thermistors. Thermistors read the temperature of the fusing rollers. This code means the thermistors thought the unit was too hot. For this reason I am hesitant to give you the service mode reset procedure as you could do further damage.
Good Luck
Nov 27, 2009 | Ricoh Aficio 2022 Black and White Copier
I have an old copier - single sheet at a time,
You don`t specify the copier models.If have one old Sharp or Canon the H codes refer to tha fuser unit:
H 2 : Thermistor open detection,thermistor open or the fusing unit is not installed correctly when the door is closed.
H 3 :Triac in the shortcircuit,heat roller abnormally high temperature.
H 4 :Heater lamp open,defective installation of thermistor,thermostat open,and causes the set temperature is not reached after turn ON the power.
Sep 26, 2009 | Office Equipment & Supplies
My bottome dryer wont heat up but the top dryer heats
I have the same problem and called a repair center to fix. They came out last Thursday and and ordered the parts (thermite and thermo fuse). Waiting for a call that they received and ready to repair.
Aug 01, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
