Question about Nikon Cameras
If i will use my memory card a message will appear that this card cannot be use?
  • kakima Mar 19, 2011
    What model Nikon camera? What size memory card?
  • 3 Answers
Try formatting your card as FAT32. Insert it into the card reader in your computer, (assuming Windows) and find it in My Computer. Right click, and format. Once completed, try inserting it into your camera again. Note: any data on your card will be lost.
Posted on Mar 19, 2011
Printer error 70
Brother DCP-165C inkjet All-in-One Printer Error Messages
Once you are familiar with the types of errors that can occur while you are using PhotoCapture Center, you can easily identify and troubleshoot any problems.brother-dcp-165c.jpg
Hub is Unusable.
This message will appear if a Hub or USB Flash memory drive with a Hub has been put into the USB direct interface.
Media Error
This message will appear if you put in a memory card that is either bad or not
formatted, or when there is a problem with the media drive. To clear this error, take out the memory card.
No File
This message will appear if you try to access a memory card or USB Flash memory drive in the drive (slot) that does not contain a .JPG file.
Out of Memory
This message will appear if you are working with images that are too large for the machine's memory.
This message will also appear when a memory card or USB Flash memory drive you are using does not have enough available space to scan the documents.
Media is Full.
This message will appear if you are trying to save more than 999 files in a memory card or USB Flash memory drive.
Unusable Device
This message will appear if a USB device or USB Flash memory drive that is not supported has been connected to the USB direct interface (For more information, visit us at http://solutions.brother.com.). This
message can also appear if you connect a broken device to the USB direct interface
Nov 03, 2010 | Brother DCP 165C Compact Color Inkjet...
I cannot change my 'Memory in use' from Phone Memory to Memory Card. 'Changing message memory in use' is appearing, but after that, nothing happens, it's still using Phone Memory as storage.
are you doing it for messages, if yes, it works properly but whenever you remove your memory card it reverts to phone memory, you have to revert setting back to memory card
Jun 27, 2010 | Nokia N73 Cellular Phone
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
Memory full. Please delete some data.
press *#7370# to reset phone but make a backup
Jun 30, 2009 | Nokia N73 Cellular Phone
Memory card problem
Promblem Regarding Memory Card of 6600 Nokia. ------------------------------------- 1). Format the memory card by the phone using "format" option available in memory card "options".
2). If still same problem appears, then format it through pc-suite software, or through memory card reader which available in market (this process is by using PC).
3). If still same problem appears, then try with a new memory card.
Because it depends on your handset. After inserting a new memory card, if the same problem appears please contact your nearest "NOKIA CARE".
All the Best....
Thanking you.
Mar 02, 2009 | Nokia 6600
Memory low n70
You need to change default storage device on your phone, from phone memry to card memory. In other words, move all data (messages, songs, videos etc) from your phone memory to card memory.
for example, go to messages>options>other>momory in use - change it to memory card instead of phone. (if your memory card is not named, it will be displayed as NO NAME).
Do the same with other data also.
Dec 13, 2008 | Nokia N70 Cellular Phone
Screen keep appear 'memory low. delete some data'
just change your prefered storage to memory card...actually your selected memory is phone memory...so thats why every file received from bluetooth save in phone memory..to change your stroage go to messages ------> settings-------> change your storage from phone to memory card....i can send you a detailed procedure if you want
Oct 10, 2008 | Nokia N73 Cellular Phone
Saving Bluetooth Messages in Memory Card in Nokia N73
go to message settings-- other settings---change memory in use to memory card by options... welcome-----. sai..saidheerajmv@gmail.com
Jun 02, 2008 | Nokia N73 Cellular Phone
Cameras Logo
13 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
