Question about JBL PRX518S Subwoofer Speaker
I'm a mobile DJ I have four pair of JBL PRX518s that i don't use often maybe once a month i get to use them but the subs keep on burning out on me this is sub # 2 to burn out me in the 18 month i have them. What causing it to burn out?
  • Thomas love Mar 03, 2012
    You need to purchase a drive rack PX because it has pre-sets for the PRX518 and it will protect them from you overloading them. Also, if you are playing them and start to hear static your problem is debri in your coil groove which means your woofer is on it way out. Purchase a spare recone kit from speaker exchange and learn to recone yourself it will save you tons.
    You need to purchase a drive rack PX because it has pre-sets for the PRX518 and it will protect them from you overloading them. Also, if you are playing them and start to hear static your problem is debri in your coil groove which means your woofer is on it way out. Purchase a spare recone kit from speaker exchange and learn to recone yourself it will save you at least $130 on a $300 repair
    Master:
  • 403 Answers
What is the area that you work in ? are you going from 1 air temp to another ? What I mean is, from home, to car, to job. Something like that have to remain at a constant temp.
Posted on Mar 19, 2011
I need the cable that got from the amp... to the spearkers
you may need one like these:
http://www.computercablestore.com/15FT_Audio_Cable_Female_X_PID8003.aspx
XLR to JBL PRX518S Subwoofer Speaker
and the other end to your AV Receiver
Sep 18, 2012 | JBL PRX518S Subwoofer Speaker
My bass cuts when playing but goes back on after a few seconds.
that because you have a loose ground to your amp or not the right size wire but check your ground on the amp it will overheat and turn off to protect itself .
Apr 13, 2012 | JBL PRX 518S PRX518S Powered Subwoofer PA...
Played at a gig last night when one of my jblprx518 subs cut out also there was a smell as if something had burnt out! Is there a simple quick fix or is it a warranty issue?
Either the speaker or the amp in it or both fried. Check to see IF your warranty will cover the repair.
Make sure that in your venues ALL interconnected equipment is powered from teh same receptacle OR power conditioner module, incling mixers, amps, speakers. Ground bounceof wiring in building power that causes damage most likely will not be covered under warranty.
Jul 31, 2011 | JBL PRX 518S PRX518S Powered Subwoofer PA...
Jbl eon g2 not giving any low sounds only tweeter works
open it up and check cables leading to sub (large speaker) they're notorious for falling off - getting banged around
Feb 17, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
The fuse keeps burning out in my jbl sub 10, even if i disconnect the input LFE.
poor design, the amps that are screwed to the heat sink are below a transistor which is catching all the heat,heat rises and changes the bias of the transistor so high it causes runway in circuits that results into failure also the amplifiers are sealed with no air flow, this can't be good.Maybe if they put air vents or remove the cover to panel then the heat will have somewhere to go instead of just building up inside.If this problem is not fixed a replacement is going to fail too.good price bad design.
Oct 08, 2009 | JBL Venue SUB10 Subwoofer
JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Oct 12, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
JBL PRX518S Subwoofer Speaker Logo
231 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
