Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
I have seagate 500gb sata freeagent. usb port broken. need to buy the pcb connector because I dont think i could solder back the broken usb port to the board. anybody know where to order?
  • charlesemorg
    charlesemorg Sep 03, 2012
    *FIXED* remove the plastic case, remove the screw holding the visible board in place, remove the 4 side screws holding the drive into the metal housing. Pull the drive and board from the housing. The green board pulls out of the main drive - remove it carefully. You're left with a drive, in the slot plug in a red sata fire wire and insert into the sata port of a desktop computer. Attach the power to the second slot. Most desktops have spare power slots inside, so look for the the one that accepts the hard drive, not the pin type. That's it, power up the desktop and the drive will appear along with your computer's hard drive, giving you access to the data. It's not a perfect fix, your external is now an internal, but you'll be able to get all the data from the drive.
Posted on Sep 03, 2012
    Scholar:
  • 60 Answers
I believe you are looking for this: USB Mini-B (5-pin) you are looking for the "socket"
Here is a list of products to choose from:
https://www.alliedelec.com/search/searchresults.aspx?N=0&Ntt=USB+Mini+B&Ntk=Primary&i=0&sw=n
Please note; This will be extremely hard. most of those products have no pictures and you are not sure exactly what you are getting, luckily they are pretty cheap so i would recommend getting a couple that sound right.
Good luck, be careful.
Hope this Helps.
Posted on Mar 19, 2011
FreeAgent Pro USB broken -- need data from Momentus drive
Momentus is a SATA drive, so you can put it in any PC that has SATA bus to access the drive.
If you can borrow a SATA to USB dock, you can put it in the dock and plug the dock to USB port on a computer to get your data out the drive.
One example for the USB dock is EZ-dock and you can search on Internet for the picture.
Apr 11, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I burned out my external hard drives PCB board and I am unable to find a new one
The Printed Circuit Board ON THE Harddrive inside the Seagate FreeAgent, or the small PCB inside the Seagate FreeAgent's external enclosure? (Case)
If you are referring to the small PCB that the Harddrive connects to, and has the USB cable coming from it, just buy an external enclosure, and install the Harddrive into it.
http://www.youtube.com/watch?v=0HZ-wTdscgc
If your Seagate is like the one in the link above, it has a laptop size Harddrive in it, and it is a SATA unit.
2.5 inches across in width. (2 and a half inches)
This is an example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
IF you are referring to the PCB on the Harddrive itself, good luck.
One method would be to buy another harddrive like the one in the Seagate FreeAgent, and use it's PCB so that you can retrieve your information.
Then reinstall the PCB on the new harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 17, 2011 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
I need the removable part that the power and usb cables connect to looks like p/n 100FC02
Don't know if you still need it but I have one that I pulled from a Seagate backup drive that I just scrapped.
I've listed it on eBay, search for:
Seagate 100FC02 USB/AC ADAPTER INPUT To SATA PCB
Oct 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
Sep 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 500GB Seagate FreeAgent external hard drive with a lot of media on it that I really don't want to lose. It's USB connection is broken so that the port sort of just floats around inside. Could...
If you cannot get the USB port fixed you can take the drive out of the inclosure and install it as a second drive in another computer that has SATA capability to get the data off of it. You can always put it back in if you can get the enclosure repaired.
Mar 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Freeagent Go 500 GB won't work.
im having the same problem tried a new drive enslosure but thats not working it says the drive is 2tb when its 500gb, which tells me the sata to usb board is fried so its not comunicationg with the computer even though the drive still spins, so im going to buy one of those sata to usb docking stations but ill have to take the drive out the case which will void the warranty. the last thing ill try is to buy a refirbished freeagent go and swap the sata to usb board, this is important, i have 200gb work of music that i need and i dont have a backup, ill post my efforts asap.
Jun 24, 2009 | Seagate FreeAgent Pro 500GB External USB...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Pls. help me with my new seagate external freeagent pro ( 500GB)
hi..there....i think if you can get e sata cable to connect between external and pc at you country is very bad news..but maybe you can get it in another store...last time when i visit bangkok thailand i'm very happy because i can get all componnet for pc..i buy a internal card reader that include the e sata connection is around 400 baht and the cable connector for it (power and data cable) is around 100 baht. so if you have friend at tahiland (bangkok) you may ask them to buy it for you and send it to your place....
Feb 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Usb connector broke on hard drive
I'm gonna guess and say the connector is a plug-in type? You'll be happy to hear that YES! all data is safe (or sould be)
You simply have to open the case, disconnect the HDD from the existing controller PCB. 1 of the connectorsis a opaque plastic PLUG with 4 thick wires (12v, Gnd, Gnd and +5v) and will have to be 'teased off' by pulling straight out and wiggling side to side, and the other is a slide-on,Black or Grey 40Pin Flatwire IDE or much smaller 8-Pin SATA connector. You can simply install it in another USB carrier of the same type (IDE/SATA) or your desktop as a spare drive. Empty USB HDD Carriers are avail from MicroCenter for $20.00 Let me know how you get on or if you need further assist.
Jan 15, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
FreeAgent 500gig External - How to open case?
I believe Seagate has a 5yr warranty with this drive. Why not have Seagate honor the warranty and have them repair or replace the drive?
Jan 16, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
275 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
