Hi
If clean light
is blinking 7 times then it may be an issue with heater circuit, door switch or
wash pump. If yes then please reset the power to the dishwasher. After, 5
minutes check if you are still getting the same error. If yes, then it is a
water heating fault. To resolve this error try pressing this reset sequence--
Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air
Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry.
Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button
and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the
water past the heater efficiently or due to lack of water to heat. Please make
sure that heater is not open circuited and is heating the water efficiently.
You'll have to check the heater using a multimeter; the meter should read
between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is
fine then make sure water pressure is optimum and fill valve is working fine.
Hope this helps... Please post back for further assistance.
Daniel
